I was swapping front discs and pads today. When I tried to unclip the connector for the wear indicator I gave it a small tug as I held the tab on the downstream side of the connector. As the connector slid apart, the upstream connector broke at the point where its held in a bracket attached to the strut.
Its no big deal, and I guess mainly due to me, but also old brittle plastic. Is it possible to get a repair unit so the upstream connector works as it should. I've taped it at the mo, but that's not ideal.
