Author Topic: What suspension do you have ???  (Read 1737 times)
Offline Kevga
« on: April 24, 2013, 09:11:15 pm »
What suspension have we all got looking to replace mine and  dont know what to go for.Not really wanting to go to low was thinking maybe lowest 30mm max. What you all think ?? :popcornsoda: :popcornsoda: :popcornsoda:
My pic was to big.
Work In Progress
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: What suspension do you have ???
« Reply #1 on: April 25, 2013, 06:52:48 am »
I'm standard at the mo but in the next month or so I'll be getting eibach sport line springs fitted, you use the same stock shocks and just replace the spring they drop about 30mm which I've been quoted £310 to have fitted supplied and the wheels aligned. If not theres h&r super sport springs which lower the car a tad more but are a little bit more to buy.
Think most just upgrade the springs
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: April 25, 2013, 07:31:05 am »
30mm would be a lowering spring on standard dampers or upgraded dampers and springs. Got H&Rs on mine but going to KW V1s soon
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: April 25, 2013, 08:17:28 am »
I have had, first, Eibach Sportlines with oem dampers...stance @ 25"
I then had H&R Super Sports with oem and now Bilstein Sport dampers, and the stance was the same except the front was 1/8" lower than the Eibachs were...so, stance was 24.8"-F and 25"-R
I recently took a coil off of the front springs only, and that dropped not only the front, but the back too...stance is now at 23.8"-F and 24.4-R
Offline skard
  • -Receive: 245
« Reply #4 on: April 25, 2013, 11:18:17 am »
Bilstein B12 Sportline kit (pics in sig)
Offline Kalpsn2000
  • -Receive: 56
« Reply #5 on: April 25, 2013, 11:33:45 am »
I have H&R Sport Springs fitted with the OEM shocks. They give a 30mm drop, which is just about right for me.
Check out my thread:
http://www.mk5golfgti.co.uk/forum/index.php/topic,51126.0.html
Offline Kevga
« Reply #6 on: April 25, 2013, 02:27:13 pm »
Yeah they all look good does any of them buff or rub though. At the moment mine buffs on hard cornering and some speed bumps (That just seem to be getting bigger)
My pic was to big.
Work In Progress
Offline stubert
« Reply #7 on: April 25, 2013, 02:56:47 pm »
VW Racing springs on standard dampers
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8 on: April 26, 2013, 02:09:24 am »
Mine is likely to be the lowest with springs...no rubbing with 18x8 wheels, 45 offset, and 225/40 tires.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #9 on: April 26, 2013, 07:37:14 am »
No rubbing on my springs but i havent done the screw arch mod either
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #10 on: April 26, 2013, 08:17:28 am »
I did, for me, a simpler screw mod...I pushed up on the two(one each side) and they bent quite easily
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: What suspension do you have ???
« Reply #11 on: April 26, 2013, 08:26:20 am »
Hi guys.
Do you only do wheel alignment when changing the front suspension or when changing back as well?.
My rear shocks need replacing.
Sent From My Samsung S3
Offline torque777
« Reply #12 on: April 26, 2013, 09:12:18 am »
I fitted eibach prosport springs to a standard tdi golf ....which are -30mm drop over standard ...eibach sportline drop -45 to-50mm on front and -40mm on rear over standard ...have to say over all springs ive used over the years these are by far the best oem style spring 8)
sent using my own fingers
