Author Topic: Mirror controller moves both mirrors at same time?!  (Read 6489 times)
Offline MrDo
« on: April 24, 2013, 09:50:07 pm »
I just swapped out my old window joystick/switch controller on my UK MK5 GTI for a chrome knobbed brand new one (as used on Passat, MK 6 etc) bought on eBay. When I set it to move the left mirror it works fine, but when I move it to adjust the right hand side mirror it moves both bloody mirrors ie both the right and the left mirrors at the same time!!
It is a joystick/switch for a RHD car. Surely this part does not need coding? Maybe a duff switch?  :sad1:
  • -Receive: 291
Re: Mirror controller moves both mirrors at same time?!
« Reply #1 on: April 24, 2013, 09:57:32 pm »
Normal behaviour and a "feature" of the golf.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: April 24, 2013, 09:59:16 pm »
I'm sure this "feature" can be disabled with VCDS  :wink:
Offline neg
  • gone old skool
« Reply #3 on: April 24, 2013, 10:11:22 pm »
Your right - on the mk6 you can enable/disable via the MFD
Offline MrDo
« Reply #4 on: April 24, 2013, 10:18:42 pm »
Why on earth would they choose to do this? Never noticed it in the past 6 month..... Funny how you miss things eh?
Anyone done this? Know the code etc?
Thanks  :happy2:
Offline neg
  • gone old skool
« Reply #5 on: April 24, 2013, 10:25:37 pm »
it does make sense, you adjust the right first then the left, then if you need to adjust (or another driver does) then adjust the right only and the left is pretty much (I have found) in the right place - then when you come to move it back, its one mirror - move to your location, check the left and if your lucky its spot on.
Offline ripmateyy
« Reply #6 on: April 24, 2013, 10:27:53 pm »
I think you can change this in convenience menu on highline
« Reply #7 on: April 24, 2013, 10:44:54 pm »
Correct, if he's got a highline mfd.
Offline MrDo
« Reply #8 on: April 24, 2013, 11:18:05 pm »
Sadly not, but I do have VCDS if I can turn off via that?
Offline neg
  • gone old skool
« Reply #9 on: April 24, 2013, 11:22:17 pm »
Yes you can.
Offline Kalpsn2000
  • -Receive: 56
« Reply #10 on: April 24, 2013, 11:34:39 pm »
Ignore, wrong thread.
Mod can delete.
