Poll
Mk5 golf GTI rattle(heat sheild vibration sounds)when letting go of pedal?
accuator
0 (0%)
wastegate
0 (0%)
Total Members Voted: 0
Author Topic: Mk5 golf GTI rattle(heat sheild vibration sounds)when letting go of pedal  (Read 9081 times)
Offline Gaj0801
Hey guys just wondering what this noise might be...any ideas but bascially....my
Mk5 golf GTI rattle(heat sheild vibration sounds)when letting go of pedal,so when letting of boost.
cheers
Mk5 Golf GTI|3DR|LC9Z|Black Magic|Ko4 converted|350+bhp|AmD Tuned|Manual -SOLD
EDITION 30|3DR|Steel Grey|Manual|#1429 -SOLD
M3|E92|Alpine White|Manual
Offline adgti
I have the same noise since fitting my downpipe
Offline GTI-Pirelli
  • -Receive: 27
My Milltek back-box is mounted a little on the high side. (Reallty couldn't be a75ed to take it off again)
It rattles sometimes at low revs, over occasional bumps and sometimes when I close the boot.
It will more than likely be the exhaust rattling against it. Remember the exhaust will move with the engine as it varies revs.
2017 Audi S4
Offline Gaj0801
Cheers guys but I'm a little worrid it might be the turbo?acuator possibly?
Offline Gazza747
I had a fault in the valve on the wastegate. I don't think it's the same as the symptons sound slightly different These are the symptons I had and so should eliminate the fault I had:
It was easiest to test while coasting downhill, at fairly low revs so no on boost I guess, in gear but foot off all pedals, so engine braking and a rattle. VW replaced the turbo under warranty.
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline broomhead50
I have a vibration/grinding noise that is most noticeable in similar circumstances as you mention above. I have noticed no difference in the cars performance what so ever but the noise is driving me mad. Someone mentioned that is could be types (Pirelli p zero's) as they are close ish to the tread bars and apparently this is a known issue but I have heard nothing about this. I'm hoping this is not a turbo problem- how long do Vw cover these items as I have an 07 ed 30 with 51k.
Can anyone offer any suggestions?
Thanks.
Offline Gazza747
Thanks.
I have vw warranty that I pay for monthly otherwise the turbo would not be covered.
Offline M7AXB
I had the same on mines, it was the mount holding the downpipe was loose. Get a look underneath and see if theres any play in that area.
Offline Gaj0801
Just a update as ive just seen this again,i had to replace the turbo as the wastegate accuator (inside end) had a lot of play in it..  :surprised:
But all is good now that i have replaced it.
Hope this helps guys!
cheers
Offline xjay1337
  • -Receive: 377
I have this noise but it sounds like it's coming from behind the fabric in the bulkhead.
Not coming from exhaust/downpipe.
Probably the metallic heatsheidling tbh.
The car boosts to 12-13psi and pulls back to 7-8 at the redline.
Idles at -20inHg.
Don't think it's actuator related.
Offline mac456
Re: Mk5 golf GTI rattle(heat sheild vibration sounds)when letting go of pedal
« Reply #10 on: October 21, 2013, 12:09:29 pm »
How much did it cost you? turbo replacement?
Offline Gaj0801
« Reply #11 on: October 22, 2013, 10:32:56 am »
Hello mate,
i won a newish turbo with low miles for £80 on ebay and i fitted it by a mate for 150 as i didnt have time to do it myself.So overall cost of £230.
cheers
