Author Topic: Does any 1 no how to solve these fault codes please  (Read 11241 times)
Offline rich golf gti mk5
« on: April 25, 2013, 05:39:59 pm »
rich golf gti mk5
Always Involved
 Online
Referrals: 0
-Given: 5
-Receive: 2
Re: Spluttering gti under load
« Reply #10 on: April 20, 2013, 08:58:06 pm »
Quote  Modify  Remove
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2173747
   Coding: 040300031C070160
   Shop #: WSC 00187 210 89766
   VCID: 2441A30BE7548338654
Report to moderator     81.98.216.227
rich golf gti mk5
Always Involved
 Online
Referrals: 0
-Given: 5
-Receive: 2
« Reply #11 on: April 20, 2013, 08:59:19 pm »
Quote  Modify  Remove
Readiness: 0010 0001
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 Q    HW: 02E 927 770 AD
   Component: GSG DSG         070 0925
   Revision: 04007000    Serial number: 00000504260321
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 214FAA1FF84696100E2
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 40890F9B130CBF1861C
1 Fault Found:
01309 - Power Steering Control Module (J500)
            008 - Implausible Signal - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70E99F5B632C6F98D1C
2 Faults Found:
00756 - Left Vent Temp Sensor (G150)
            010 - Open or Short to Plus
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001834378
   Coding: E68D8F2700041800001400001400000000097F075C
   Shop #: WSC 00558 210 00001
   VCID: 2B5348378A8A4C40A4E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00558
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 00558
10 Faults Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
02498 - Left Low Beam Reflector Motor (V294)
02499 - Right Low Beam Reflector Motor (V295)
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
00906 - Horn (H1)
            009 - Open or Short to Ground - Intermittent
02071 - Local Databus
            004 - No Signal/Communication - Intermittent
01321 - Control Module for Airbags (J234)
01320 - Control Module for Climatronic (J255)
02389 - Release Signal Transmission; Position P/N
01520 - Rain and Light Recognition Sensor (G397)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 08 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0DMTT2
   Coding: 0012344
   VCID: 377B644746C2F8A0D06
1 Fault Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
Re: Does any 1 no how to solve these fault codes please
« Reply #1 on: April 25, 2013, 05:42:48 pm »
   Coding: 0000020
   Revision: 00T12001
   Coding: 0004738
1 Fault Found:
2 Faults Found:
   Coding: 00065493
   Shop #: WSC 00558
   Coding: 00207646
   Shop #: WSC 00558
10 Faults Found:
00906 - Horn (H1)
   Coding: 0012344
1 Fault Found:
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012122
   VCID: 77FBA447064238A0106
   Part No: XXXXXXXXXXX
   Component: E0221           007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0024403
   Shop #: WSC 00999 444 64523
   VCID: EED50123F918F968430
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010551901DE
   Coding: 3F0F0340070001
   VCID: 2A5D4D33857055485F8
4 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
01315 - Transmission Control Module
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H03 0800
   Revision: AB001001    Serial number: VWZ6Z7H7178053
   Coding: 040004000400001200
   Shop #: WSC 00020 790 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2D57462F749E4270BAA
3 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
03138 - Input AUX IN
            011 - Open Circuit - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2310
   Coding: 0000564
   VCID: 3665694341C801A8CB0
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.1   D04 1606
   VCID: 3363505752BA1480ECE
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 18C802487F6D0C0DC85AC65010CC
   Shop #: WSC 12345 785 00200
   VCID: 78F9A77B0B5C37D819C
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000564
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
3 Faults Found:
            011 - Open Circuit
Offline GTI-Pirelli
  • -Receive: 27
« Reply #2 on: April 25, 2013, 06:39:54 pm »
Have you had problems with the battery recently? A low battery might cause intermittent comms between modules. The airbag module is showing low battery sensed. This would be my first port of call.
Or
Incorrectly coded or faulty CAN gateway????
There are quite a few modules with intermittent communication / Implausible signal.
Or
Have you changed any coding recently?
Or mice living in your car chewing through all of your wiring?
Good luck!
2017 Audi S4
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #3 on: April 25, 2013, 07:25:22 pm »
Sell it and buy a new one! Thats a hell of alot of errors!
I joke of course  :happy2:
« Reply #4 on: April 25, 2013, 07:35:56 pm »
I have vagcom n changed a few bits. Ie anti hi jack windows up on key fob etc . How do I put correct codes in. I've thought about selling aswell lol but love it too much.
Offline jbc
« Reply #5 on: April 25, 2013, 08:10:23 pm »
If all you've changed is some coding for the door locking then I can't see how this could have generated faults in all these different controllers. Have you done a clear all faults with VCDS to see which ones come straight back again? Then you'll know what faults you've got now, not ones it logged 6 months ago.
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
« Reply #6 on: April 25, 2013, 09:26:30 pm »
I had a longer list than that and all i did was change my rear lights and the car was brand new. I wouldn't worry about it.  :happy2:
« Reply #7 on: April 25, 2013, 09:58:42 pm »
Cleared it with vag they cum back straight away. Not that worried really its if any ones got the codes who could help me eliminate a few that would be great.
Offline GTI-Pirelli
  • -Receive: 27
« Reply #8 on: April 26, 2013, 07:00:14 am »
Did you by any chance scan and save a log before you started to change the coding?
If you did there will be a nice list of the coding for every module in your car.
2017 Audi S4
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #9 on: April 26, 2013, 07:36:11 am »
Is everything working on the car as it should? If things are, i wouldnt worry about them. Have you checked on the ross tech site for the codes or just googled them?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #10 on: April 26, 2013, 08:22:29 am »
It's likely due to a power disconnect and just needs resetting/clearing the fault codes. If no vcds, then a service shop. You can search here where all codes are, and if not just enter the code in the search box. Then look for the causes and solutions after selecting the code.
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
« Reply #11 on: April 27, 2013, 07:53:07 am »
I did disconnect the battery but its been reset now 3 times n no I didn't save a log before I made changes like a idiot  :stupid:
Offline edd666999
  • -Receive: 89
« Reply #12 on: April 27, 2013, 09:41:05 am »
Non of those errors relate to your hesitation with acceleration. They would generally be logged under engine if there were any
« Reply #13 on: April 27, 2013, 11:19:43 am »
Now I've got overboost error then goes into limp mode
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #14 on: April 28, 2013, 11:16:40 am »
Is this the code now:http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
