Author Topic: HELP NEEDED !!!  (Read 1128 times)
Offline barney
HELP NEEDED !!!
« on: April 25, 2013, 10:55:53 pm »
3 fault lights keep coming on wile driving its the ABS light traction control and the tyre pressure light if I flick the ignition off and on again it goes off but comes back on agin I've checked the tyre pressure and reset the inflation alarm what eles could it be and has any one eles had this fault
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: HELP NEEDED !!!
« Reply #1 on: April 25, 2013, 11:42:55 pm »
Do you have access to VCDS, if not check out the owner register to see if there is anybody close to you who could run a scan.
Offline barney
Re: HELP NEEDED !!!
« Reply #2 on: April 26, 2013, 06:54:11 pm »
No I don't have access to one il have a look tho thanks do you know if I can check anything before I get it plugged in thanks
Offline Bane
  • "I was born a handsome man and now I'm half a goat
Re: HELP NEEDED !!!
« Reply #3 on: May 06, 2013, 08:55:55 pm »
Hi mate,just seen this post.
I have a similar problem,but both the ESP light and the TPM lights are on constantly.
Turned out to be the ESP sensor pack located underneath the drivers seat which is an expensive fix. :scared:
A little internet digging turned up a fair few similar problems across the VW range..mine is an 07 plate.
I called VW to see if they would help as it's a known fault, but mine is a different fault code to all the rest(typical!) but VW have conceded to 20% of the cost of repair. :happy2:
Get it checked at a dealer,then see if VW will cover the cost or partially cover it,if it's the correct fault code.
If not,then places like Autotek can either repair the faulty unit,or replace it on an exchange basis with a recon unit.
HTH.
