Author Topic: Can anybody help overboost.  (Read 1951 times)
Offline rich golf gti mk5
« on: April 27, 2013, 04:58:42 pm »
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
perfect finish
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WVWZZZ1KZ6W003165   Mileage: 128870km/80076miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0001
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2173747
   Coding: 040300031C070160
   Shop #: WSC 00187 210 89766
   VCID: 2441A30BE7548338654
3 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 001 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 128796 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:40:58
             Freeze Frame:
                    RPM: 759 /min
                    Load: 16.9 %
                    Speed: 0.0 km/h
                    Temperature: 73.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 128831 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:54:26
             Freeze Frame:
                    RPM: 1625 /min
                    Load: 22.3 %
                    Speed: 32.0 km/h
                    Temperature: 47.0°C
                    Temperature: 13.0°C
                    Voltage: 14.478 V
000564 - Boost Pressure Regulation
               P0234 - 001 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 128861 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:19:27
             Freeze Frame:
                    RPM: 2885 /min
                    Load: 100.0 %
                    Speed: 76.0 km/h
                    Temperature: 16.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.478 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 Q    HW: 02E 927 770 AD
   Component: GSG DSG         070 0925
   Revision: 04007000    Serial number: 00000504260321
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 214FAA1FF84696100E2
1 Fault Found:
18250 - Please check DTC Memory of Instrument Cluster
            P1842 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Reset counter: 1
                    Mileage: 128843 km
                    Time Indication: 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 40890F9B130CBF1861C
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70E99F5B632C6F98D1C
2 Faults Found:
00756 - Left Vent Temp Sensor (G150)
            010 - Open or Short to Plus
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001834378
   Coding: E68D8F2700041800001400001400000000097F075C
   Shop #: WSC 00558 210 00001
   VCID: 2B5348378A8A4C40A4E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00558
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 00558
2 Faults Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 128713 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 128713 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 08 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0DMTT2
   Coding: 0012344
   VCID: 377B644746C2F8A0D06
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012122
   VCID: 77FBA447064238A0106
   Part No: XXXXXXXXXXX
   Component: E0221           007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0024403
   Shop #: WSC 00999 444 64523
   VCID: EED50123F918F968430
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
            010 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010551901DE
   Coding: 3F0F0340070001
   VCID: 2A5D4D33857055485F8
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 31
                    Reset counter: 24
                    Mileage: 128713 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:53:49
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H03 0800
   Revision: AB001001    Serial number: VWZ6Z7H7178053
   Coding: 040004000400001200
   Shop #: WSC 00020 790 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2D57462F749E4270BAA
2 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 32
                    Reset counter: 24
                    Mileage: 128712 km
                    Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 128713 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:54:39
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2310
   Coding: 0000564
   VCID: 3665694341C801A8CB0
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.1   D04 1606
   VCID: 3363505752BA1480ECE
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 18C802487F6D0C0DC85AC65010CC
   Shop #: WSC 12345 785 00200
   VCID: 78F9A77B0B5C37D819C
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000564
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
            012 - Electrical Fault in Circuit - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            008 - Implausible Signal
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 32
                    Reset counter: 24
                    Mileage: 128712 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 128713 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:54:39
End   ---------------------------------------------------------------------
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Can anybody help overboost.
« Reply #1 on: April 29, 2013, 06:36:08 am »
It will be a bad sensor if over-boost has suddenly shown up. http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Engine/Electrical/Sensors/Boost_Pressure/
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #2 on: April 30, 2013, 04:08:32 am »
Do you have a boost gauge? If you are creating enough boost then you likely need the boost sensor.
http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
