Author Topic: HELP - Bloody cars!!  (Read 2575 times)
Offline Johnny_tro
« on: April 27, 2013, 08:27:02 pm »
thought I have everything sorted on the car, how wrong can one be. So can anyone please help me.....car is a 04 GT TDI
1. Bloody bonnet out cable has snapped. How do I now open the bonnet? How hard is this to replace?
2. When I pull away I get an almighty WHOOOOSHHH. Something is clearly blowing/gone?
 :sad1:
« Last Edit: April 27, 2013, 08:41:14 pm by Johnny_tro »
Offline Johnny_tro
Re: HELP - Bloody cars!!
« Reply #1 on: April 27, 2013, 08:41:40 pm »
 :sad1: :sad1:
« Reply #2 on: April 27, 2013, 08:44:35 pm »
the whoosh noise could be a pipe come of ie the intercooler one the battery side
Offline rich golf gti mk5
« Reply #3 on: April 27, 2013, 08:46:01 pm »
May b dump valve don't no about bonnet.
Offline GTsport
« Reply #4 on: April 27, 2013, 08:48:31 pm »
:sad1: :sad1:
I'm not sure how you go about the bonnet catch.
But the whooshing sound, sounds like a boost leak to me. But obviously you need to get under the bonnet to investigate  :scared:
Offline Bow
« Reply #5 on: April 27, 2013, 08:50:52 pm »
I thought my bonnet catch had snapped as pulled and it went horribly wrong. To open need some patience remove the badge you can access the catch you will need a thin screw driver with end bent into a hook look through the hole for badge you will see what's needed. Mine had just popped out of the holder where two cables meet
Offline Johnny_tro
« Reply #6 on: April 27, 2013, 09:30:09 pm »
The noise seems to be moving from drivers side in/around the wheel arch area. Sounds like it anyway. Def a big wooooshwhen you accelerate. Sounds expensive. .. .
I do still have power. . .
« Reply #7 on: April 27, 2013, 09:45:59 pm »
the intetcooler cooler pipe run down that side as well
Offline Johnny_tro
« Reply #8 on: April 27, 2013, 09:49:08 pm »
If this has gone, should the car not be peeeeeing out water? Can't see any leaks? Fluid on the floor or drippings.
Offline Dannyboy88
« Reply #9 on: April 27, 2013, 09:53:27 pm »
No as intercooler pipes carry air.
Offline mortygttdi
  • -Receive: 146
« Reply #10 on: April 27, 2013, 09:56:20 pm »
If intercooler pipe there'll be no fluids.
The pipe that comes out of the turbo is rubber then goes onto a metal pipe where it then goes to the intercooler, if its around the wheel arch area then the turbo rubber hose may have just popped off.
« Reply #11 on: April 27, 2013, 09:59:38 pm »
Good to see you on here Darron
Offline Johnny_tro
« Reply #12 on: April 27, 2013, 10:01:05 pm »
Thank you all. I really hope it's just it's just a pop off. Now way I can ££££ a new turbo......was my first thought.
How's best to access this pipe? From under front bumper? Via wheel arch?
Offline Johnny_tro
« Reply #13 on: April 27, 2013, 10:04:00 pm »
Intercooler pipe - please confirm this runs from and to?
Offline Dannyboy88
« Reply #14 on: April 27, 2013, 10:18:46 pm »
Is there no one near you on here johnny who could have alook for you?
