Author Topic: Loba LO400(380)  (Read 17291 times)
Offline neg
  • gone old skool
Re: Loba LO400(380)
« Reply #30 on: July 06, 2013, 08:02:03 am »
You will struggle to get everything for under £2k. I reckon this will be more like a £3k inc vat and fitting.
Is that on top of a Stage 2 setup or stock?
Ideally ... LO400 setup + Stage 3 DSG Map for me
Re: Loba LO400(380)
« Reply #31 on: July 06, 2013, 08:25:51 am »
If you want a new L0400 it is €1,975, if you can get hold of a used K04 and send it off for conversion then that drops to €1,295 ( plus more shipping costs ). The GIAC map would be circa £500 unless you are already a GIAC customer and there would most likely be quite a bit off that. Then if you decide on GIAC you will require RS4 injectors as this is what their map requires. These are around £400. Then fitting on top.
So, the cheapest route would be for an existing GIAC customer using a refurbed K04 for just over £2k all in for the map, injectors, refurb turbo and fitting.
The most expensive route would be a new customer for around £3k.
An RS3 in tank pump or equivalent would be a good idea too and that would be another £400 ish.
Offline neg
  • gone old skool
Re: Loba LO400(380)
« Reply #32 on: July 06, 2013, 08:31:09 am »
Wow, didn't realise the injectors and in tank pump were so much
Re: Loba LO400(380)
« Reply #33 on: July 06, 2013, 08:34:28 am »
From stock you'd require......
Full turbo-back exhaust
Intercooler ( required at this level of tune )
Uprated in-tank pump ( recommended but not essential)
Uprated HPFP
Uprated intake with larger MAF housing ( if going GIAC )
Lower dogbone mount insert ( as a minimum )
Cooler sparkplugs
L0400 Turbo
Rs4 injectors (if going GIAC )
Appropriate remap.
Also I'd probably look at the E-Boost 2 upgrade, but that ain't cheap, but worth it. :happy2:
« Last Edit: July 06, 2013, 08:36:55 am by Hurdy »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Loba LO400(380)
« Reply #34 on: July 06, 2013, 03:00:14 pm »
Uprated HPFP
Cooler sparkplugs
L0400 Turbo
Appropriate remap.
I'm glad you like the Eboost so far Hurdy  :happy2:
Over the top mod list ;o)
Re: Loba LO400(380)
« Reply #35 on: July 06, 2013, 04:50:59 pm »
Uprated HPFP
Cooler sparkplugs
L0400 Turbo
Appropriate remap.
Yeah,
It is much better than I thought it would be. So, so clever little piece of kit.I'd have bought it just for the "Knightrider" boost lights alone.  :laugh:
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Loba LO400(380)
« Reply #36 on: July 21, 2014, 11:31:47 pm »
I see Loba have a summer sale on and have knocked off 200 euro off the price of the LO400.
Roll up, Roll up.... :signLOL:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Loba LO400(380)
« Reply #37 on: July 21, 2014, 11:40:20 pm »
How come you have not got one of these yet ????  :party:  Now would be a good time!  :driver:
Silver is the way !
Offline neg
  • gone old skool
Re: Loba LO400(380)
« Reply #38 on: July 21, 2014, 11:56:27 pm »
Nortech kits where it's at  :laugh:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=tnubbvldd12111he2lc7pclmdj&/topic,19740.0.html
Re: Loba LO400(380)
« Reply #39 on: July 21, 2014, 11:57:20 pm »
 Yeah. It's also 5000 minimum.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Loba LO400(380)
« Reply #40 on: July 21, 2014, 11:58:39 pm »
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Loba LO400(380)
« Reply #41 on: July 22, 2014, 12:10:38 am »
How much of a difference will this make over the KO4 turbo, will it sound different, spool different, pull harder, longer ?  :party:
Would it show much over a well sorted KO4 set-up?
 :popcornsoda:
Silver is the way !
Re: Loba LO400(380)
« Reply #42 on: July 22, 2014, 12:13:33 am »
Well storted ko4 will do 370-380 with WMI.
Re: Loba LO400(380)
« Reply #43 on: July 22, 2014, 12:19:53 am »
It spools the same as a K04. Loba claimed slightly better, but I didn't feel much difference on the butt dyno.
Mid range to top end it was better. On my set-up it was around 28bhp peak gain. Torque is slightly stronger and holds on longer at the mid to top end too.
To make the most from it you need a suitable map. A boost controller is also an option, but not a necessity. :)
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Loba LO400(380)
« Reply #44 on: July 22, 2014, 09:21:15 am »
John, as i think you are the only person to try this would you recommend giving it a go or as Sy said earlier in this thread is it only really worth it for people coming up from the KO3 by bypassing KO4 conversion and go straight for this? It seems to me that if you are expecting 400PS from it you may well be disappointed going off Statller's figures for the 4XX
