Author Topic: Jacking up with a trolley jack  (Read 4937 times)
Offline acme
« on: April 28, 2013, 10:55:28 pm »
Evening all,
I'll be jacking my MK5 up for the first time to change wheels, I note that the jack with the car has a recess on it to go into a metal lip about 1cm deep at the four corners, I will be using a trolley jack and assume you simply put the jack under this metal lip? Daft question possibly but I'm use to cars with a 'proper' jacking point, often with a point wide enough for a proper trolley jack.
Cheers in advance for any responses.
Offline xjay1337
  • -Receive: 377
Re: Jacking up with a trolley jack
« Reply #1 on: April 28, 2013, 11:02:48 pm »
Really?
There are double-seamed parts of the sill to jack up from. In the owners manual bro.  :jumpmove:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: April 28, 2013, 11:21:30 pm »
There are some proper jacking points under removable plastic plates, but you can use the reinforced sill ones with your trolley jack... Remember to use axle stands too  :happy2:
Offline acme
« Reply #3 on: April 29, 2013, 10:29:31 pm »
Really?
I noted the jacking points in my initial post, the owners manual only talks about platform lifts and the original jack, not using a trolley jack as other cars I've raised do, I've never seen a reinforced seem before, most odd. To think the cars being raised on that one cm wide piece of metal seems a little odd.
Offline acme
« Reply #4 on: April 29, 2013, 10:30:43 pm »
Many thanks for your reply. Odd again that the manual doesn't mention the plastic plates, I'm beginning to think VW don't want you to do any work yourself!
« Reply #5 on: April 29, 2013, 10:56:38 pm »
Here is a thread from a while back pertaining to the Butt plug lifting points.  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,684.0.html
