Author Topic: Golf GTi Pirelli - High end audio installation  (Read 6041 times)
Offline Squeeguk
« on: April 29, 2013, 11:25:39 am »
Thanks to one of our forum member's, I was entrusted with the honour of installing a high end audio system in his beloved GTi Pirelli.
What an amazing car, probably THE most sorted MK5 out there with ballistic performance, both accelerating and stopping wise.
The brief was simple, top end components and great sound quality and a minimalist boot build. The components list is as below:
Audison Voce Quattro amplifier
Audison Voce 5.1k amplifier
Hertz Mille MLK 3PA - 3 way component system
Hertz Mille MLK 2TW - 2 way component system
Sound deadening by Skinz
Cabling, distribution and Capacitors by Connection by Audison
All of this is being driven by Alpine's top of the range INE-W928R 8" Fully featured head unit.
Here is a pic of everything that was to go into the car.
First off, started with stripping all the trim out of the interior, and then running the various cables required.
Then proceeded to remove the door skins and apply a good covering of Skinz sound deadening, along with running the new speaker cables through the factory OEM positions into the door.
Cables in the door were wrapped with cloth tape and neatened up, along with placing the woofers into the doors.
Custom mdf mounts had to be fabricated for the mid range speakers. The doors were also covered in Skinz panel liner to ensure no resonance of the panel.
Once the doors had been taken care of, the head unit was installed and the RCA interconnects run down the middle of the car under the central trim.
The interior could then go together while the boot build started. Here is the board all cut and carpeted. There is a frame underneath which allows all the cables to be run underneath hidden and provides rigidity to the board to prevent it warping.
Once the carpeting had been done, the components were screwed down onto the board and the cabling sorted it was installed in the car. Some Skinz sound deadening was placed around the spare wheel well to help reduce the noise in this area. The wheel well area was kept clear as the second stage of the build will involve a subwoofer and a complete rebuild of the boot area to accommodate this.
The finished product.
Last point of business which had been put off was to complete the A pillars with tweeters covered in genuine Alcantara. These were positioned ever so slightly off axis.
This is what the dash looks like with the Alpine 928R in place.
During the build last week, I also had the opportunity to fit an amplifier, Alpine IVE-W535BT and new speakers in the owners son’s Corsa VXR Nurburgring.
Both cars sound incredible, but the outstanding impression of the system in the Golf is superb clarity. There is still loads to come from the system, with the speakers needing to be broken in and then the system fully tuned to the customer’s taste.
Re: Golf GTi Pirelli - High end audio installation
« Reply #1 on: April 29, 2013, 11:51:19 am »
very indeed and excellent  work
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: April 29, 2013, 01:56:42 pm »
Great job there but how much does all of that weigh?!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 29, 2013, 05:33:56 pm »
amazing work :drinking:
Cluster and Key coding
Location Great Yarmouth
Offline Squeeguk
« Reply #4 on: April 29, 2013, 07:10:31 pm »
Thanks guys.
Does weigh quite a bit Joe, but the aim was to keep it as light as possible, hence the really simple boot build using only 9mm thick MDF. The two amps, being top notch Audison units, came in at 14.5 kgs in total. Having said that, the car has an obscene amount of power and the spare wheel was also removed.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: April 29, 2013, 07:18:36 pm »
^^^ i bet it sounds amazing without it OTT and in your face
Offline pitsirikas
  • -Given: 19
« Reply #6 on: April 29, 2013, 07:26:56 pm »
Amazing job......... :happy2:
A couple of questions if I may...
Why you haven't use the OEM position for the tweeters..?
Why no sub?
                     Don't drive faster than your angel can fly..!
                Respect a man's car and the man will respect you
Offline Squeeguk
« Reply #7 on: April 29, 2013, 07:55:51 pm »
Why no sub?
Thanks.
To answer your questions:
1. The OEM tweeter position is too low to be properly effective when it comes to the overall sound staging. Having them in the A pillars allows you to aim them effectively and bring them up closer to ear level which seems to provide a more natural sound. Having them in the stock locations means they are very close to the mids. This system has been built with pure SQ in mind, hence the only option was to pillar mount the tweeters.
2. You would be amazed how good it sounds without the sub, which great bass thanks to the 6.5" woofers in the stock locations. This setup will probably cover 90% of all music you could want to listen to. The sub only really coming into it's own when very low frequencies are being played. Having said that, the second phase of this build is to have a totally reworked boot area with either a 10" or 12" sub in the wheel well. The only reason this wasn't done from the word go was due to time constraints as the customer lives outside of the UK and only comes home occasionally. Didn't want to take up all his holiday time, hahahahahaha.
Hope this clarifies?
« Reply #8 on: April 29, 2013, 09:25:51 pm »
Very nice Luis.  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=1k7llt7mfsg036s1kopov5c92g&/topic,19740.0.html
« Reply #9 on: April 29, 2013, 09:37:55 pm »
NIce... but where does the shopping go now?  :laugh:
« Reply #10 on: April 29, 2013, 09:44:20 pm »
With the DJ in the car behind.  :pomppomp:
Offline edd666999
  • -Receive: 89
« Reply #11 on: April 29, 2013, 09:46:15 pm »
Could you pm me the estimated labor costs for installing all this bar the rear components?
Offline Squeeguk
« Reply #12 on: April 30, 2013, 08:50:14 am »
Thanks mate, much appreciated.
Offline Squeeguk
« Reply #13 on: April 30, 2013, 08:51:49 am »
Hahahahaha, to be perfectly honest, I think this car has no idea what shopping is, let alone a shopping trip. This is more like a rolling example of what can be done with a MK 5.
Offline sanj
  • -Given: 17
« Reply #14 on: April 30, 2013, 07:29:28 pm »
Fantastic install Luis and so much detail,love the look of that head unit! :happy2:
