Author Topic: DIY injector change  (Read 2873 times)
northyracing
DIY injector change
« on: April 29, 2013, 03:48:38 pm »
As title says has anyone done a DIY on this job or is it that hard of a job that its best letting vw do it
Offline dokez
Re: DIY injector change
« Reply #1 on: April 29, 2013, 04:41:45 pm »
Its straight forward. Just removing the nuts/bolts off the inlet manifold as that has to come off first.
Saintsteve
« Reply #2 on: April 29, 2013, 04:55:53 pm »
I was told an injector pulling tool may be required to do this?
Someone may confirm this?
Offline dokez
« Reply #3 on: April 29, 2013, 04:56:44 pm »
northyracing
« Reply #4 on: April 29, 2013, 05:28:07 pm »
To be fair that don't look that bad of a job might have to look into doin this just so I can diagnose if the injector is my problem
northyracing
« Reply #5 on: May 01, 2013, 07:44:59 pm »
Can anyone tell me exactly what parts I need e.g gaskets etc also any part numbers would be ideal
« Reply #6 on: May 01, 2013, 10:33:04 pm »
You will need an injector repair kit for each injector you remove.
Part number 06D 998 907
Saintsteve
« Reply #7 on: May 02, 2013, 07:28:13 am »
Inlet manifold seal kit also.
northyracing
« Reply #8 on: May 02, 2013, 07:38:55 am »
So I will need injector, repair kit and inlet manifold gasket
« Reply #9 on: May 02, 2013, 07:59:25 am »
Yup.
northyracing
« Reply #10 on: May 02, 2013, 08:30:09 am »
Cheers mate I just thought I needed just a new injector and inlet gasket
Offline edd666999
  • -Receive: 89
« Reply #11 on: May 02, 2013, 09:26:48 am »
Doesnt look that difficult  :pomppomp:
northyracing
« Reply #12 on: June 08, 2013, 08:16:40 pm »
Can't seem to find an injector to fit the axx engine have I got to get one that's just fits the axx of can you use another engine code injector also when I change them will I have to code them or is it a straight forward swap over
