Author Topic: Accidental over revving incident...  (Read 2640 times)
Re: Accidental over revving incident...
« Reply #15 on: April 30, 2013, 08:27:52 pm »
If you've done it good and proper you will have one of these stored.
000537 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
               P0219 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 8
                    Mileage: 66095 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:54:02
             Freeze Frame:
                    RPM: 7265 /min
                    Load: 9.4 %
                    Speed: 221.0 km/h
                    Temperature: 90.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
Readiness: 0000 0000
The part in bold is from the nice folk in Ross Tech.  :wink:
Offline jimk04
« Reply #16 on: April 30, 2013, 08:38:23 pm »
Think the limiter is 7200?
FOr some reason when doing some logs in mine, I gunned it to the limiter, but it never came! I saw well over 7200 so though best change gear!
Mine logged that engine Warranty thing and showed me similar to yours...7250 or something, but no issues at all.
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline G40will
« Reply #17 on: April 30, 2013, 08:47:26 pm »
Could that code be cleared or because of its nature would it be hard stored on the ecu?
