Author Topic: BBK safety face caliper clearance on spokes  (Read 1757 times)
Offline kylej1
« on: May 01, 2013, 05:42:51 pm »
Fitting a BBK but trying to avoid spacers, have 1.5mm clearance on the face of R8 calipers till the spokes, running 19x8 bbs ck wheels with et44 and dont want to go a mark the face of the new r8 calipers, what clearance have you guys got on the BBKs on your cars
thanks
Re: BBK safety face caliper clearance on spokes
« Reply #1 on: May 01, 2013, 07:15:54 pm »
Ouch, slap a 3mm spacer in there...
Offline kylej1
« Reply #2 on: May 01, 2013, 08:36:10 pm »
I maybe able to take 1mm off the carrier to allow the caliper back in, what clearance would be advisable? Have a 3mm spacer but don't fancy using them long term as I hate when the wheel isn't resting on the hub
« Reply #3 on: May 01, 2013, 10:45:48 pm »
Someone correct me if I'm wrong but with 3mm spacer there should still be some protruding hub for the rim to sit on.
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: May 01, 2013, 10:49:14 pm »
Depends on the wheels, but yes a 3mm spacer should still allow the wheel to rest on the hub.
Follow AKS tuning on Facebook
Offline tony_danza
  • -Receive: 112
« Reply #5 on: May 01, 2013, 11:04:12 pm »
Remember, things expand when they get hot....
Sideways yo!
Offline DFish
« Reply #6 on: May 01, 2013, 11:24:31 pm »
Wouldn't you then have to have new bells made to allow for the moving of the caliper? Otherwise you'd be putting pressure on the disc.
Fish
Offline kylej1
« Reply #7 on: May 02, 2013, 08:17:17 am »
Fish
If I had to redo the bells it would be worth it, will run with the 3mm spacers and see how it goes thanks
Has anyone upgraded the rear brakes I had the s3/r32 caliper at the moment
