Author Topic: Air-con head ache  (Read 602 times)
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Air-con head ache
« on: May 03, 2013, 06:28:37 pm »
I've recentley had my air-con system vacuum tested and regassed and all was fine and I've just changed the cabin filter myself which was filthy but the problem is the air-con isn't cold but the garage I went to said that the air-con pump is kicking in and i can hear a noisey fan working in the engine when the aircon is on but I'm not sure if this is normal.
Has anyone had this problem before or can help me out I could really do with it sorted?
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Re: Air-con head ache
« Reply #1 on: May 03, 2013, 07:10:39 pm »
Small fan should be working when your AC is turned on.
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #2 on: May 03, 2013, 07:32:33 pm »
Both fans were working but it is a lot noisier when the aircon is on.
I've read there could be some sort of switch which hasn't turned on?
Type_R
« Reply #3 on: May 03, 2013, 09:28:07 pm »
Unfortunately this information is not true.
On the MK4 Golfs the small fan comes on with the A/C but on the MK5 if the ambient temperature is low (I would guess less than 15C) then it does not come on straight away.
I fell into the trap of people telling me that there was something wrong as neither of my fans were coming on with the A/C with ambient temps of 10C. I tested with VCDS, both fans behaved normally. I pulled the fuse and put it back in again, no problems.
Today I started the car with an ambient temp of 16.5C, turned the AC on and the fans turned on at low speed. I asked someone on here to check their MK5 GTi as well and their's behaved exactly like mine. I know that the 2.0 TFSi Audi A3 behaves like mine too, so I doubt there is any evidence to suggest that the 'small fan always comes on with the AC.'
