Author Topic: *Help Needed* EPC and Traction Lights. Fuel Cut/Limp Mode.  (Read 7924 times)
Offline jimk04
Re: *Help Needed* EPC and Traction Lights. Fuel Cut/Limp Mode.
« Reply #15 on: May 05, 2013, 09:00:32 am »
I could scan it.today for ya....coming to Lincol late morning.
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline chungster
« Reply #16 on: May 05, 2013, 09:02:32 am »
Not you as well Carlo!
I had this fixed in Feb by Alex. Stealer tried to fix this under warranty / goodwill, by diagnosing it as throttle pedal problem and replacing that. Fault came back after 1 week. Gave me the spiel that if it's the TB they won't fix it and it's the remap that's caused the fault  :stupid:
So just had Alex replace the TB in the end.
All good now apart from injector 4 failing. Back to AKS next week.
« Reply #17 on: May 05, 2013, 09:27:37 am »
That would be Amazing Jim if you could.  :notworthy:
I'm in all day anyway.  :happy2:
Ill pm you my details!  :smiley: :smiley: :smiley:
« Reply #18 on: May 05, 2013, 09:30:26 am »
Yes Matey  :sad1:
Looks like this is quite a common issue then.
Ill see what the scan comes up with before I start to worry. :scared:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=f59c5mkmt3v0fjk9cqj6v1arer&/topic,19740.0.html
« Reply #19 on: May 05, 2013, 09:57:45 am »
With a throttle body problem, when would it cut the fuel and how would you know.>
hope that doesn't sound like a silly Q?
Believe me Neil you would know.  :wink:
As you accelerate hard, you are pulled back into your seat, then when the fuel cuts out you are thrown forward like you have just pressed the brake.
The fuel only cuts out for less than a second so then when it picks up again you accelerate as normal, pushing you back in your seat.  :laugh:
Where in Lincoln are you Monte?
I'm in Saxilby Jim (just off the A57)  :happy2:
Hmm. If the car picks up as normal after the loss of power it suggests (from my experience) that it wouldn't be a TB problem but a fuel pressure issue.
With my TB issue the car remained in limp mode after the loss of power
Offline RoMocop
« Reply #20 on: May 05, 2013, 10:41:53 am »
Can you not try your old spark plugs again to see if you still have the issue.
« Reply #21 on: May 05, 2013, 12:15:02 pm »
I bet you have this fault code, just like I suffered last night:
It means you will need a new throttle body.
You are correct Alex  :sad1:
Jim has just been round with his VCDS.
WHAT A TOP LAD  :notworthy: :notworthy: :notworthy:
Thank you So much Jim. Sorry for making you late.  :ashamed:
Fault found
Angle Sensor2 for Throttle
(G188)
000536   -  P0222
Fault was cleared and lights have gone out on dash and it seems to be fine :happy2:
....for now anyway. I suspect it will happen again though.  :ashamed:
Should my Revo settings have been adjusted again after the IC?
Need to get this sorted.
« Reply #22 on: May 05, 2013, 12:21:19 pm »
Just drive it off boost and it will be ok....
Offline jimk04
« Reply #23 on: May 05, 2013, 05:34:54 pm »
No probs Carlo you didnt make me late, I made myself late by looking at your lovely car....need me an RNS!
PM me your email CArlo and I will send you the logs.
Oh and Rich, what does 'drive it off boost' mean, surely this isnt possible! :grin: :grin: :wink:
Offline jimk04
« Reply #24 on: May 05, 2013, 05:36:11 pm »
Found your address in your profile mate so no worries.
Offline vRSAlex
  • -Receive: 253
« Reply #25 on: May 05, 2013, 06:59:14 pm »
Fault will come back on as soon as you go full throttle.
Follow AKS tuning on Facebook
Offline Gti_Mad
« Reply #26 on: May 05, 2013, 11:29:27 pm »
i recently had this also and had 2 fit a new throttle body 2 weekends ago now  :sad1:
« Reply #27 on: May 05, 2013, 11:57:18 pm »
Its seems to be happening all over  :surprised:
Need it sorting ASAP.  :happy2:
This was the log from the 1st scan.  :surprised:
(I had Thousands of faults from changing MFSW, Climate, RNS, Phone, Bulbs etc. They all Some cleared though)  :ashamed:
Sunday,05,May,2013,03:35:58:56661
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 77
VIN: WVWZZZ1KZ7W123965   Mileage: 73630km/45751miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 L    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH15---    Serial number: VWZ7Z0F8193497
   Coding: 040300031C070160
   Shop #: WSC 78128 411 411174
   VCID: 2F666822BEC01960886
1 Fault Found:
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 73618 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:45:24
             Freeze Frame:
                    RPM: 4552 /min
                    Load: 100.0 %
                    Speed: 155.0 km/h
                    Temperature: 81.0∞C
                    Temperature: 28.0∞C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 044 T    HW: 02E 927 770 AE
   Component: GSG DSG         070 1301
   Revision: 04507000    Serial number: 00000610260423
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 26488D06913A58287B0
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   VCID: 73EEA45212687D802CE
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000005938804
   Coding: E58D8F2700041500471400001400000000087F075C0001
   Shop #: WSC 00000 785 00200
   VCID: 6CDCBF2E4F56A278ED4
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 081106 020  0501
   Coding: 00038805
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     151106 020  0105
   Coding: 00208933
   Shop #: WSC 00000
7 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.80 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01505 - Bulb for Blinkers; Rear Right (M8)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.80 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.20 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.20 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01504 - Bulb for License-Plate Light (X)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 13.40 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00984 - Left Tail Light (M4)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.50 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 71775 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.45 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0VL6EZ
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D7A426A64ACFBF00AA
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0001834
   Shop #: WSC 12345 123 12345
   VCID: 7AF0897635020CC86F8
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Shop #: WSC 00000
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 973     HW: 1K6 920 973
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8193497
   Coding: 0003403
   Shop #: WSC 00678 210 71758
   VCID: F0E42B5EE37EC69851C
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 161106F2001493
   Coding: 3F0F03C807000001
   Shop #: WSC 07975 795 00500
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
   Shop #: WSC 00000 000 00000
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26017 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:21:11
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H64 4120
   Revision: AB001001    Serial number: VWZ6Z7M7112003
   Coding: 00000402040000200000
   Shop #: WSC 00787 210 95039
   ASAM Dataset: ------------------------- ------
   VCID: 336E645292E83D80ECE
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V8  7690
2 Faults Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 170
                    Mileage: 68562 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:25:48
00862 - Antenna for GPS Navigation (R50/R52)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 210
                    Mileage: 69006 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:36
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0968
   Coding: 0000628
   VCID: 3874537E4B8EDED8D9C
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00678 210 91841
   VCID: 36685D46419A28A8CB0
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81900A085103087F2D04840570085AC690B800
   Shop #: WSC 12345 785 00200
   VCID: 830E7492C2C8CD00BCE
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000628
   VCID: 3972567A7084C7D0262
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            008 - Implausible Signal
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 170
                    Mileage: 68562 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:25:48
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 210
                    Mileage: 69006 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:36
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 B    HW: 1Z0 035 729 B
   Component: FSE_2P7x        H31 0050
   Revision: 00000001    Serial number: 00000005009915
   Coding: 0000422
   VCID: 377650424690D1A0D06
End   ---------------------------------------------------------------------
« Last Edit: May 06, 2013, 12:07:38 am by monte »
« Reply #28 on: May 06, 2013, 12:06:33 am »
2nd Scan.
Still a few faults.  :sad1:
Auto HVAC-Cannot be reached?
Steering wheel-Intermittent wiper switch?
Immobilizer-Control Module?
Navigation-Phone Mic?
Radio-Phone Mic?
Want to get these sorted too.  :ashamed:
Sunday,05,May,2013,03:47:05:56661
Chassis Type: 1K0
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Readiness: 0110 0100
   Coding: 0000020
   Revision: 00H11001
   Coding: 0004738
Cannot be reached
   Coding: 00038805
   Shop #: WSC 00000
   Coding: 00208933
   Shop #: WSC 00000
   Coding: 0013112
   Coding: 0001834
   Coding: 00000131
   Shop #: WSC 00000
1 Fault Found:
            014 - Defective
   Coding: 0003403
1 Fault Found:
            014 - Defective
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26017 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:21:11
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 73633 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:43:36
   Coding: 0000628
   Coding: 0000628
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 73633 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:43:36
   Coding: 0000422
« Reply #29 on: May 06, 2013, 03:27:22 pm »
Anyone any ideas about the microphone fault?
It seem to all work fine  :confused:
