Author Topic: Slow to boot up??  (Read 1345 times)
Offline dajonic
  • -Given: 17
Slow to boot up??
« on: August 03, 2009, 07:55:07 pm »
Hi all, I've got a problem with the sat nav unit. Its the 510 unit and if I just turn the ignition key it boots up straight away but as soon as I fire up the engine it turns off then takes an age to turn back on. Is this a coding issue or a wiring problem? I thought I had it coded correctly but maybe not. Cheers for any ideas.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Slow to boot up??
« Reply #1 on: August 03, 2009, 08:01:49 pm »
Sounds like a wiring issues with the permanent 12v live as it should only take time to boot when it has been fully powered off  :confused:
