Author Topic: New Brake Pads for ED30  (Read 2112 times)
Offline jamiew
« on: May 08, 2013, 08:38:38 am »
Hi guys, need to replace my pads but have no idea what to buy, im not looking to spend massive ammounts and the ferodo ds2500 are a bit pricey.
I see the ferodo ds performance pads for allot cheaper, any 1 have any experience with these, or have any other suggestions for pads, i am looking to spend up to arround £130
Thankyou
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: New Brake Pads for ED30
« Reply #1 on: May 08, 2013, 09:13:38 am »
I'd go for some OEM pads, they'd be cheaper than Ds2000 and absolutely the very same material, I'd give your dealer the chassis or reg number from an edition 35 and give them a go. Whilst you're there get some new OEM discs and a brake fluid change on fixed price and your brakes will be factory fresh.
There's little point in spending extra on a mediocre setup, it is what it is but renewed it should stop from all but silly speeds and give a good pedal
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #2 on: May 09, 2013, 10:20:16 pm »
Just out of interest - what is the difference between the ED30 pads and the Edition 35 ones you refer to?
Change in compound?
Edition 30 - no. 1387
Offline jamiew
« Reply #3 on: May 15, 2013, 08:48:57 am »
Would u recommend these as a slight upgrade to the standard setup on my ED30?
http://pages.ebay.com/link/?nav=item.view&id=120705952528&globalID=EBAY-GB
http://pages.ebay.com/link/?nav=item.view&id=290510275819&globalID=EBAY-GB
or just stick with standard discs and pads?
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: May 15, 2013, 09:32:01 am »
If you are just doing normal driving then I would stick with the oe discs and pads.
Offline jamiew
« Reply #5 on: May 15, 2013, 11:53:26 am »
well i am soon to be getting stage 1 remap, with miltek catback, and i have an itg maxogen already on the car
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: May 15, 2013, 12:27:54 pm »
i have some HAWK pads for sale in the sale thread. I would say they are a few pages back
but look them up !
Silver is the way !
Offline jamiew
« Reply #7 on: May 15, 2013, 12:53:56 pm »
tbh i am just wondering if it would be worth me upgrading from oem to the ebay grooved discs n pads, or if they are actualy not very good etc. just want some people thaughts
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: May 15, 2013, 01:06:06 pm »
My first brake upgrade was night and day difference  :happy2:
Didnt realise how much better, an upgrade like that would make...
 :driver:
Silver is the way !
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #9 on: May 15, 2013, 01:18:38 pm »
I've found that the standard 312 discs with OEM pads and fresh OEM fluid is as good as everything but race pads like: Mintex 1144s / Ferrodo DS2500.  I've tried DS performance pads and Tarox Strada... my result=save your money, no better than standard.
The drilled/dimpled/grooved discs look cool, but don't offer anything over the standard disc with the standard callys; buy them for aesthetics but not for a performance advantage.
Standard R32/S3/Cupra 345 discs and bigger calipers offer a noticeable upgrade in stopping power over the 312's, did for me.
Not tried NQSBBK, but I'd expect these to be better again, with a weight saving over the 345 disc setup... although, your walking down the line of £600+
If you have £130 as a budget, follow DaveB's recommendation and get some OEM kit (if they are low) and most importantly new OEM fluid carried out by someone who knows how to fully bleed the system with ABS purge.  I've found a properly bled system with fresh fluid makes a world of difference. :happy2:
Offline Trev.
« Reply #10 on: May 15, 2013, 01:22:15 pm »
How much fluid is needed for a full change?
Im looking at buying some and it comes in 500ml or 5 litre bottles lol
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #11 on: May 15, 2013, 01:39:41 pm »
Of those two amounts, the 5L... although it's not good to leave it, as it's hygroscopic and all that jazz.
When I grabbed some from VW it came in 1L tins.  Make sure you get the right spec. stuff.  iirc 501.14 or newer.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #12 on: May 15, 2013, 01:47:37 pm »
The dealers most likely don't cycle the ABS.
I wonder if you have VCDS could you cycle it yourself and then drive to the dealer for the fluid change?
'07 Red manual
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #13 on: May 15, 2013, 01:59:31 pm »
I changed to black diamond groved disc's
ebc red stuff pads
braided lines
And castrol brake fluid
all round!
The difference was crazy...
Silver is the way !
Offline jamiew
« Reply #14 on: May 15, 2013, 02:00:16 pm »
so the following isnt worth it?
I have attached some prices below for the EBC discs and pads:
EBC slotted discs front (pair) - £124.12 + VAT
EBC slotted discs rear - £103.29 + VAT
Front red stuff pads - £65.84 + VAT
Rear red stuff pads - £56.68 + VAT
Labour - £110 + VAT
