Author Topic: Hpfp issues  (Read 760 times)
Offline paulmk5gti
Hpfp issues
« on: May 09, 2013, 11:33:10 am »
As above bought hpfp with upgraded internals from someone on here. Had pump fitted and massive fuel leak from the front of pump! So fix that leak! Then yesterday tryed the pump again and no fuel pressure. At idle I have 7bar of pressure when requested is 50bar! Witch suggests knackered pump. So reinstall my old pump and at idle I get 50bar! Have tryed to contact the seller but no replys at all. Any suggestions on what to do next ? ??????
Sent from my GT-I9300 using Tapatalk 2
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Hpfp issues
« Reply #1 on: May 09, 2013, 01:16:12 pm »
take it apart and rebuild it
then start to try fittings of your old working pump  :happy2:
good luck man!
Silver is the way !
Re: Hpfp issues
« Reply #2 on: May 09, 2013, 04:49:35 pm »
Who did you get the pump from??
Offline paulmk5gti
Re: Re: Re: Hpfp issues
« Reply #3 on: May 09, 2013, 05:04:25 pm »
pm'd
Offline W8 Performance
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
Re: Hpfp issues
« Reply #4 on: May 09, 2013, 10:28:22 pm »
It doesn't look like he has been online since the 3rd.
I would suggest stripping it down and rebuilding it.
There are instructions here - http://www.autotech.com/mm5/instructions/i127100k.pdf
More pics here - http://www.autotech.com/download/2.0TPump/FuelPump.zip
I hope it's nothing too serious and just needs a clean up.
Rob :happy2:
Offline paulmk5gti
« Reply #5 on: May 10, 2013, 05:51:51 am »
Rob :happy2:
thanks Rob .
Is there any way to tell if the internals are upgraded after I disassemble the pump any markings etc?   Regards Paul8)
Offline dokez
Re: Hpfp issues
« Reply #6 on: May 10, 2013, 07:00:16 am »
Autotech, the piston has a step up, and oem one is just 1 straight size. Youll havet to pull it out of the hpfp to see it.
Offline paulmk5gti
« Reply #7 on: May 10, 2013, 07:10:15 am »
spot on thanks for the info :)
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
Re: Hpfp issues
« Reply #8 on: May 10, 2013, 07:37:10 am »
When you strip it down you will find it also say autotech on the part and has a serial number.
