Author Topic: tdi owners egr valve gasket  (Read 2765 times)
Offline holland15h
« on: May 11, 2013, 07:00:48 pm »
Just a quick mention if you didn't know,  there is a gasket from a skoda and seat that restricts the amount of gas fed back in. I put one on my car today as its cheaper than an egr delete . it seams smoother and has a better pick up. The gasket cost me £2.54 from tps. Part number 028131547b. Below is a picture of the difference between the 2,
Offline Trekmeister
  • Golf GT 140
Re: Re: tdi owners egr valve gasket
« Reply #1 on: May 11, 2013, 07:23:43 pm »
Would it not cause a build up to develop over time causing a blockage?
Offline holland15h
« Reply #2 on: May 11, 2013, 07:45:02 pm »
Possibly over a long period
Offline Trekmeister
  • Golf GT 140
« Reply #3 on: May 11, 2013, 09:40:01 pm »
Apparently you can reduce the amount of gas going through the egr using VCDS.
Offline Matto
  • -Receive: 116
« Reply #4 on: May 11, 2013, 11:28:09 pm »
I think this was also a way to stop the stutter the some 170's would suffer with.
Offline xjay1337
  • -Receive: 377
« Reply #5 on: May 12, 2013, 12:16:14 am »
Yeah I believe this is true, if not you can do it as part of a remap, basically set the EGR to constantly be open (as little gas recirculation as possible). You could also just put a solid washer over the return pipe.  :party:
