Author Topic: MFSW - Connectors - Do i need anything else?  (Read 5142 times)
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« on: August 05, 2009, 03:57:44 pm »
Just got my MFSW controls through from ebay. Not bad for £54 inc P&P.
Can anyone tell me whether i need anything else? I have the steering wheel controls, the red ribbon connections, and a small TRW box that the red ribbons go into.
Also, i have noticed that on the steering wheel controls there are some small 3 pin connects in the white blocks. What are these for?
« Last Edit: August 05, 2009, 04:20:43 pm by Deako »
#1493
Offline mortygttdi
  • -Receive: 146
Re: MFSW - Connectors - Do i need anything else?
« Reply #1 on: August 05, 2009, 05:22:02 pm »
Hi mate so you got them through, the 3 pin conectors should be for your paddle shift wiring one in each side of the box. But you shouldnt need that box you got with the new buttons cos you'll already have one in to control your paddle shifts.
Darren
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #2 on: August 05, 2009, 05:25:08 pm »
Cool, im sure it will make more sense once i get the bag off.
Is there anything i need to be careful of when removing the airbag? Should i disconnect the battery first?
#1493
Offline mortygttdi
  • -Receive: 146
« Reply #3 on: August 05, 2009, 05:30:00 pm »
defo disconnect the negative cable on the battery mate,  nothing to watch for all will be self explanitary when you get the air bag off...best get a small mirror and place it behind the steering wheel.
Behind each spoke on the wheel you'll see the clip you need to undo to the get the bag off.
Darren
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #4 on: August 05, 2009, 05:46:36 pm »
Cheers Darren. Will post some pics once i have swapped the inserts. Also need to find some suitable small bolts to hold them in place.
#1493
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: August 05, 2009, 05:59:17 pm »
The inserts you have in already should have the small screws in so all you need to do is take the bag off and unscrew the inserts and replace with your new buttons,  not sure they will work with out coding but hope for you they are plug and play.
Darren
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #6 on: August 05, 2009, 07:43:08 pm »
Awesome, i hadnt read your last post. Assumed the inserts would just be pop off/on. Well happy when i saw they had the screws already.
Steering wheel controls are now fitted and working. The only thing that doesnt work is the menu button, however, i can still get to the menu by pressing and holding one of the up/down arrows as per the stalk. Happy days!!!
Quick pic taken on the iPhone after installation and uploaded directly to Photobucket!!
#1493
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: August 05, 2009, 08:02:23 pm »
I have that same problem with the menu button and like you I can get into the menu with the up down buttons??? wierd but no real problem I suppose.
Darren
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #8 on: August 05, 2009, 08:27:14 pm »
Just assume it needs coding properly to make all the buttons work as they should. Happy that thats not needed desperately though, and it functions perfectly fine as it is.
#1493
Offline keith
« Reply #9 on: August 05, 2009, 09:05:01 pm »
I wished I had specced this as an option but i just took the highline instead, is this a simple thing to retro fit if you just have the h/line? and arent dsg'd.
is there and ebay seller flogging them or was it just a one of sale?
Offline mortygttdi
  • -Receive: 146
« Reply #10 on: August 05, 2009, 09:18:30 pm »
You'll need an proper MFSW Keith it was just the DSG wheel had the set up that fortunatley the buttons could be retrofitted afterwards,  The standard S/wheel can not be retro fitted with the buttons.  But the good thing is the standard gti wheel still gets a good price on ebay roughly £100+ and you may pick a good gti/r32 mfsw up for around £150+ nothing else is needed.
Darren
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #11 on: August 05, 2009, 09:50:05 pm »
Would a mod be able to move this to a technical section please? Might help someone in the future more if its in the right section. Cheers.
#1493
Offline keith
« Reply #12 on: August 05, 2009, 10:20:24 pm »
Darren
Thanks Darren, the search continues.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #13 on: August 06, 2009, 10:37:55 pm »
Morty. Discovered my menu button now works.  :pomppomp:
#1493
Offline ollie288
« Reply #14 on: August 19, 2009, 06:59:54 pm »
sell me your highline cluster!!!!!!!!   :P :jumpmove:
how did you get the menu to work?
 :drinking:
