Author Topic: Reading dtc's  (Read 3088 times)
Offline Markyed30
Reading dtc's
« on: May 15, 2013, 09:03:39 pm »
I can't seem to read any codes with my bluefin is it not compatible or am I doing something wrong ??
Saintsteve
Re: Reading dtc's
« Reply #1 on: May 15, 2013, 09:26:33 pm »
You may need to speak to Superchips to get them to enable that facility on your handset.
Offline Markyed30
Re: Reading dtc's
« Reply #2 on: August 16, 2013, 11:55:36 pm »
You should be able to read the fault codes with a bluefin on this type of car. Plug the bluefin into the diagnostic port, and at the first prompt, when it says Check ignition off and press Y, press N instead and then turn the ignition on. This will lead you into a menu where the first item should be Diagnostics.
That sorted it can data log with it aswell now  :pomppomp:
Offline Spadds
Re: Reading dtc's
« Reply #3 on: August 26, 2013, 10:07:56 pm »
What does the hand set data log?  I've got my old handset sat in a drawer collecting dust. Is it of any use then???
Offline Markyed30
Re: Reading dtc's
« Reply #4 on: August 29, 2013, 10:41:40 pm »
Not tried it yet going on
Holiday tomorrow so car has no map and immobilised will try it when I'm back  :jumpmove:
