Author Topic: bonnet release cable inop...  (Read 7286 times)
Offline lowlife
« on: August 05, 2009, 09:17:16 pm »
i think the cable may of snapped or come undone somewhere, any of you folk know of telling how, or if it has? Plus i cant gain access to the engine compartment.. :confused:
Re: bonnet release cable inop...
« Reply #1 on: August 05, 2009, 09:23:14 pm »
is there no tension on the handle when u pull it? u can twist the front vw badge off to get in to the catch or jack the car up and take the osf wheel arch off just enought to get your hands in to pull the cable
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #2 on: August 05, 2009, 09:24:55 pm »
id take the badge off, its far easier.....theres 3 bolts, 2 behind the badge and 1 behind the grill, you have to bend the grill up to gain access with a spanner or socket set.  :smiley:
Offline lowlife
« Reply #3 on: August 05, 2009, 09:48:47 pm »
yep, no tension on the release handle...
I take its a common fault with em? I had the badge off earlier, but all i could see was 2 bolts holding what looked like the latch in place.
Offline keith
« Reply #4 on: August 05, 2009, 10:59:04 pm »
mines is like that almost, it pops but wont release it keep meaning to get it looked at under warranty.
Offline lowlife
« Reply #5 on: August 06, 2009, 11:52:59 am »
took the badge off, found the 2 torx screws, but cant see the third..
Offline joesgti
« Reply #6 on: August 06, 2009, 02:21:14 pm »
if your looking at the 2 screws then the third is on the left, behind the grill, you have to undoo the bottom of the grill (2 screws inside the bottom grill) then lift the whole grill up, and bend it out towards you, then you can see the third! HTH  :smiley:
Offline lowlife
« Reply #7 on: August 06, 2009, 09:42:32 pm »
thanks man
