Author Topic: VAGCOM Fault codes - engine and radio  (Read 1753 times)
Offline dan_gti5
« on: May 16, 2013, 09:37:13 pm »
Hi all,
I ran a diagnostic on the car yesterday and the following faults came up - are these common faults and what should I be looking for if so? The battery seemed dead so I have replaced it, not sure if that would cause any?
Engine:
Code: [Select]
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F332####
   Coding: 040300031C070060
   Shop #: WSC 00148 210 9####
   VCID: 2D5B176DB40####
5 Faults Found:
008801 - Boost Pressure Control Valve (N249)
               P2261 - 008 - Mechanical Malfunction
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 10
                    Mileage: 107276 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:20:52
             Freeze Frame:
                    RPM: 2893 /min
                    Load: 11.8 %
                    Speed: 43.0 km/h
                    Temperature: 74.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.478 V
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 110084 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 114 /min
                    Load: 100.0 %
                    Speed: 0.0 km/h
                    Temperature: 79.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 9.652 V
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 110646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:51:22
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 28.0°C
                    Temperature: 26.0°C
                    Voltage: 11.176 V
012403 - Fuel Pump Circuit
               P3073 - 004 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 110646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:26:25
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 25.0°C
                    Temperature: 24.0°C
                    Voltage: 10.287 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0000 0000
Radio:
Code: [Select]
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680
   Component: RNS-MID       H11 2760
   Revision: AB001001    Serial number: VWZ6Z7K9325051
   Coding: 06010400040000A200
   Shop #: WSC 72907 146 87015
   ASAM Dataset: ------------------------- ------
   VCID: 2E591061790C649
4 Faults Found:
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 173
                    Mileage: 88485 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:06:26
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 173
                    Mileage: 88485 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:06:28
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 193
                    Mileage: 110646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:14:34
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 193
                    Mileage: 110646 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:53:49
Offline SI-R32
  • -Receive: 125
Re: VAGCOM Fault codes - engine and radio
« Reply #1 on: May 16, 2013, 09:44:13 pm »
best not to get fixated on faults that may have been with the car a long time, reset them all, wait for a day or so of driving then check again, then start looking into them
Offline dan_gti5
« Reply #2 on: May 16, 2013, 09:50:02 pm »
Good shout Si, I just did the KM conversion and those must have been awhile ago. I will clear them (pretty sure I saw an option for this in VAGCOM) and see if any return. I just assumed they were recent faults but obviously they aren't.
Cheers for that :)
