Author Topic: Alarm trouble  (Read 2173 times)
Offline Jamie3184
Alarm trouble
« on: May 17, 2013, 01:23:28 am »
Only owned the car for around 2 months but there seems to be a problem with the alarm and just wondering if anyone has had the same issue.
It will just go off for no reason what so ever, sometimes as soon as a few seconds after i have locked it or as lond as a good few hours. Stops going off as soon as i have pressed the unlock button on the fob. It can go days or even weeks without going off.
Its not really a massive problem but is quite embarrasing at times and i'm pretty sure i've just woken half the street because of it  :ashamed:
I also don't have VCDS to plug into the car to check it. Any help is appreciated  :happy2:
Offline sandancer
Re: Alarm trouble
« Reply #1 on: May 17, 2013, 06:59:48 am »
Sounds like a faulty alarm siren, mine did the same and it had to be changed. Fairly easy job though, it's located under the drivers side wheel arch liner, hardest bit is getting the rivets drilled out on the steel cover. After that it's just a case of swapping them over.
Don't buy new from the dealer, plenty on ebay 2nd hand from about £20 or even new ones from £35-£40
Part number is 1k0951605c
By the way, it may not show up any fault codes on a VCDS scan but can still be faulty.
The internal batteries corrode and eat into the circuit board, that's why they tend to fail
Offline Jamie3184
Re: Alarm trouble
« Reply #2 on: May 17, 2013, 12:27:15 pm »
Excellent, thanks for that  :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Alarm trouble
« Reply #3 on: May 17, 2013, 12:43:38 pm »
If it does show a fault on the scan it will say faulty siren H12. Or something along them lines
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Alarm trouble
« Reply #4 on: May 17, 2013, 01:07:09 pm »
get a scan done before you buy a new horn, also check to see what the trigger was
Cluster and Key coding
Location Great Yarmouth
Offline Jamie3184
Re: Alarm trouble
« Reply #5 on: May 17, 2013, 01:19:23 pm »
Thanks, much appreciated  :happy2:
Yes will do, think i may have found someone who has vagcom that can scan it for me  :happy2:
Offline blackmagic
Re: Alarm trouble
« Reply #6 on: May 17, 2013, 06:31:43 pm »
My alarm did this annoying neighbours in middle of the night! Mine was also the siren. When I opened it up found that it has its own internal pcb rechargeable battery which had leaked over the circuit board and corroded everything. Worth vcds scan thought as previous said might be a sensor.
Black GTI K03 Revo Stage 2+,
Offline Jamie3184
Re: Alarm trouble
« Reply #7 on: June 03, 2013, 02:31:31 pm »
Turns out its the door lock module that is playing up, its also damp which suggests a leak. Not sure where the leak could come from, the windscreen is a non genuine VW item though apparently so maybe from there.
Add in having rear wheel bearings that need replacing and my locking wheel nuts are done up so tightly that they need drilling out its turning into a very expensive month  :sad1:
Feel like getting it all fixed and just selling the car, definately quickly falling out of love with it  :sad1:
