Author Topic: EGR Delete's  (Read 1372 times)
Offline JD_26989
EGR Delete's
« on: May 17, 2013, 02:44:03 pm »
Hey folks,
Fitted a makeshift EGR delete to my car but after a short period of time the CEL comes up with a message "Emissions Workshop!", had the code read and cleared by my local friendly garagae and reconnected my EGR.
Was wondering anyone in the Shropshire ( pref Telford or Shrewsbury)  / West Mids area could map out just the EGR ?
Thanks folks  :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: EGR Delete's
« Reply #1 on: May 17, 2013, 03:00:58 pm »
REVO or Darkside developments should be able to help you out  :happy2:
Over the top mod list ;o)
Offline holland15h
Re: EGR Delete's
« Reply #2 on: May 17, 2013, 04:12:07 pm »
Ant at ap automotive in Telford could probably map it out in conjunction with shark performance, top guy is ant
Offline JD_26989
Re: EGR Delete's
« Reply #3 on: May 17, 2013, 04:33:47 pm »
I've already spoken to AP Automotive. My car is already mapped by the guys up at Awesome GTI, bit of a trek just for an EGR delete.
AP Automotive would only do it as part of a full remap of there own software. They wouldn't want to touch another companies map. Which I totally understand..just annoying though :P
Offline torque777
Re: Re: EGR Delete's
« Reply #4 on: May 17, 2013, 05:02:18 pm »
Right I live in telford ...so you could try elite in halesfield ..they do mapping, dpf delete and egr deletes and do whatever you want ...my mate has just had just his dpf deleted only ,by them so you could try ?
sent using my own fingers
Offline W8 Performance
  • Trader - 2014
  • -Given: 19
  • -Receive: 29
Re: EGR Delete's
« Reply #5 on: May 17, 2013, 07:11:03 pm »
Buy the egr delete kit from darkside and then get awesome to tweak your map to allow for the egr delete. Simples.  :happy2:
Offline AndrewJB
  • die gelbe Baron
Re: EGR Delete's
« Reply #6 on: May 17, 2013, 07:26:40 pm »
Nobody will tweak another companies map to do a EGR delete
Take it back to Awesome or Pay for more mapping simples.
I drove around for 6 months with my light on when i had my PD170
Offline JD_26989
Re: EGR Delete's
« Reply #7 on: May 17, 2013, 09:03:52 pm »
I am very tempted to just drive it with the light on, the code that came up was along the lines of EGR Valve Insufficient Flow so its clearly the one that needs to be removed.
Would the general consensus to be just don't worry about the CEL till I can get it mapped out ?
Offline AndrewJB
  • die gelbe Baron
Re: EGR Delete's
« Reply #8 on: May 17, 2013, 09:11:31 pm »
Yes as i said i drove around for 6 months with light on before i had my mapping changed. I got the same error code. i just used to clear it every now and again.
Offline PDT
  • -Receive: 142
Re: EGR Delete's
« Reply #9 on: May 17, 2013, 09:18:03 pm »
It's a bit of a drive, but I would gladly map this out for you FOC. It's a simple single map change.
