Author Topic: Wobble bolts are they safe and how do they actually work?  (Read 2450 times)
Offline Kemnaychris
As above
There's a set if wherls I really want but there 5x110 :(
Would wobble bolts or what ever there called will it put it to 5x112? Safely ?
2005 blue gray 140 gt tdi
Offline tony_danza
  • -Receive: 112
Re: Wobble bolts are they safe and how do they actually work?
« Reply #1 on: May 17, 2013, 08:48:19 pm »
Yes, but PLEASE get pukka TUV approved ones, rather than some Chinese tat off ebay.
Sideways yo!
Offline Kemnaychris
« Reply #2 on: May 17, 2013, 09:32:57 pm »
Cheers are they expensive and who sells them?
Offline tony_danza
  • -Receive: 112
« Reply #3 on: May 18, 2013, 12:01:24 pm »
I got them off a trader on here who sells wheels, the name escapes me at the moment, so I'll look it up.
Pretty much every Italian car on aftermarket wheels will be on PCD correction bolts, as nobody bothers making 4/5x98 wheels for a limited market, when 4/5x100 are so mainstream.
A bolt with a eccentric washer is not in itself dangerous, you'll find them use all over the place on cars, suspension usually to allow camber correction. Where people fall foul is not having the correct centrebore/spigot ring. The wheel itself must be centred tight to the hub, you can't run say a 60mm centrebored wheel on a 57.2 (iirc?) VAG, as if it moves, then there's a chance you'll slip the wobble bolts too and you're in a whole world of pain.
These were 5x114.2 and as you can see, took a lot of abuse on track.
link to supplier
« Last Edit: May 18, 2013, 12:03:43 pm by tony_danza »
Sideways yo!
Offline Kemnaychris
« Reply #4 on: May 18, 2013, 12:42:39 pm »
Oh rite cheers for that :-)
I just can't understand how they work it's like ur alloy holes are perfect with holes in hub but can't see how these bolts work as offset is few mm different lol
Might just be me but when inserting bolts it's like they fit perfect but wobble bolts move alloys few  mm is that what they do ?
Offline tony_danza
  • -Receive: 112
« Reply #5 on: May 18, 2013, 07:23:56 pm »
The taper part of the nut is more like a washer, with a bigger hole which allows it to sit at a slightly different point than the centreline of the bolt - thus correcting the PCD.
Sideways yo!
Offline Kemnaychris
« Reply #6 on: May 19, 2013, 08:33:41 am »
Oh rite cool lol anyone know the prices of these and where u get them from?
Offline Russ_leeds
« Reply #7 on: May 19, 2013, 12:35:07 pm »
someone has posted a link to supplier 3 posts up  :happy2:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
