Author Topic: Aircon Blowing Hot Air  (Read 4406 times)
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« on: August 06, 2009, 01:40:08 pm »
Got my car back from it's 3 year/60'000 miles service last week (car has done 25,000 miles) and have used the aircon for the first time this afternoon, and on LO it is blowing hot air?
What's going on?!
Offline Oli
  • -Given: 19
  • living the dream....
Re: Aircon Blowing Hot Air
« Reply #1 on: August 06, 2009, 01:42:10 pm »
Your air con system needs a service and recharge, quite common at that sort of age
www.bmvs-camperhire.co.uk - Brand new VW California SE rental
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #2 on: August 06, 2009, 01:50:41 pm »
Check that the fans come on when you turn the air con on. Not the blower fans, but the ones on the radiator.
Mine havent been coming on, its going into the dealership for the 4th time on the 18th to have the compressor replaced under warranty.
3 times it has been in for fault finding, when i told them it was the compressor the first time it went in.  :jumping:
#1493
  • -Given: 32
  • -Receive: 78
« Reply #3 on: August 06, 2009, 01:52:19 pm »
Is it not something that is done when it's serviced Oli?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #4 on: August 06, 2009, 02:02:04 pm »
No, not done as part of a normal service schedule.
#1493
Offline Oli
  • -Given: 19
« Reply #5 on: August 06, 2009, 02:03:35 pm »
No only if you ask for it - Im surprised, as dealers usually recommend it/force it upon you!
Cost should be £50+VAT for a full air con service and re-gas, thats what we charge anyway.
Offline icenutter
« Reply #6 on: August 06, 2009, 02:17:52 pm »
The compressor failed on my car.  Apparently is was something to do with the switch on its end.  The temperature of the air seemed to be fine, then one day it suddenly wouldn't blow cold.  I took it to get recharged at an independent garage and they tried and failed to recharge it.  VW fixed it under warranty.
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
  • -Given: 32
  • -Receive: 78
« Reply #7 on: August 06, 2009, 04:12:16 pm »
Damn it, I wished they'd said it might need doing when they serviced it, because now I'm going to have to book it in an faff around getting lifts etc! Oh well, can't have hot air blowing in my face!
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #8 on: August 06, 2009, 04:18:19 pm »
Think VW are still doing an offer of full service, recharge and refresh for either £69 or £79. :smiley:
Sepang Blue S4 BE Avant
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #9 on: August 06, 2009, 04:18:57 pm »
It only takes 15-30 minutes to do. Doesnt need to be a dealer. In fact, there are cheaper air con specialists out there.
#1493
  • -Given: 32
  • -Receive: 78
« Reply #10 on: August 06, 2009, 04:19:41 pm »
Hmm, just started the car, and put the aircon on. The two fans behind the radiator are not spinning. I'm guessing they should be right?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #11 on: August 06, 2009, 04:20:06 pm »
Yes, they should spin even if the aircon needs recharging. This is what is wrong with my car, and its a faulty compressor that is causing it. Its seized.
#1493
  • -Given: 32
  • -Receive: 78
« Reply #12 on: August 06, 2009, 04:24:37 pm »
Ah balls, cost? Car's not under warranty.
Offline icenutter
« Reply #13 on: August 06, 2009, 04:36:17 pm »
Are you ready?
£1022 inc VAT...
  • -Given: 32
  • -Receive: 78
« Reply #14 on: August 06, 2009, 04:36:53 pm »
Guy at IVS (an independent VW specialist) says that if there is not enough gas the aircon won't kick in at all? It's all French to me.
