Author Topic: Will much arch work be needed?  (Read 1188 times)
Offline v6yna
« on: May 21, 2013, 06:28:35 pm »
Ive had the screw mod done on the front arches, and am getting them rolled this week, but want to know if they will have to be pulled out if i want to run 19x9 et45? anyone know? Cheers
Offline valle
Re: Will much arch work be needed?
« Reply #1 on: May 22, 2013, 02:33:18 pm »
depends how low would u go ...
Offline v6yna
« Reply #2 on: May 22, 2013, 05:10:40 pm »
its on air, so doesnt matter too much running height, but when dropped i would like them to tuck...
Offline xjay1337
  • -Receive: 377
« Reply #3 on: May 22, 2013, 05:13:12 pm »
I am pretty sure a 19x9 et 46 hits the strut.
I know Bentley wheels are 19x9 et41 which is about the most you can go on a front. At et45 you might need a 5mm spacer.
Offline RedED30
  • -Given: 19
« Reply #4 on: May 26, 2013, 04:29:57 pm »
correct, 9's on the rear will leave you a little room for some camber, not sure on fronts - assuming your running a 35 profile tyre?
Revo Stage2 - With Linear Throttle
Revo DSG
BCS Turboback Powervalve - This is a must.
ITG Closed Intake.. wooosh
Here to enjoy and help, with a hint of sarcasm, please do not be offended
