Author Topic: 18x10 et38 Oz Futura 5x112  (Read 3396 times)
Offline Jabarton99
« on: May 22, 2013, 04:07:48 pm »
Hi
Anyone ever fitted something this wide to a mk5 GTI 18x10 et38 Oz Futura 5x112
The fronts are fine as there 8.5" but I'm worried about the rears.
R32 Recaro bucket seats (individual colour), Golf R MFSW with cream stitching, Cream stitched gear gaitor to match, RNS510, highline cluster, Ko4 turbo, Forge twintercooler, Forge oil catch can & washer bottle, Autotech fuel pump, Neuspeed power pully, S3 injectors, ITG maxogen intake, Red top coil packs, Milltek Full 3" exhaust straight through. AP Coilovers, H & R Anti roll bars, Tarox 10pot calipers front & S3 rear calipers rear.
Offline Adriano
Re: 18x10 et38 Oz Futura 5x112
« Reply #1 on: May 22, 2013, 04:30:36 pm »
you can fit but must be  215/40/  or 205 45 tyres
car wihout drop as woman without boobs...
Offline graeme
« Reply #2 on: May 22, 2013, 04:31:44 pm »
I think they would be close but i recon they would fit... what are they on the back 9? 9.5 ?
205 or 215  40's or 35's  would probably help
« Last Edit: May 22, 2013, 04:33:47 pm by graeme »
Offline Adriano
« Reply #3 on: May 22, 2013, 04:32:57 pm »
it's 18x10 et38 215/40/18 Falken 512s (air ride)
« Last Edit: May 22, 2013, 04:38:00 pm by Adriano »
Offline Jabarton99
« Reply #4 on: May 22, 2013, 04:47:15 pm »
I wish they were 9" or 9.5 but there 10"
Adriano, how is the poke, they stick out a bit but look good
Offline Rob.
« Reply #5 on: May 22, 2013, 05:39:48 pm »
Has that had much arch work? Looks like it would work with 225s, just that the arch would sit on the tyre instead of the rim when dumped?
Offline Jabarton99
« Reply #6 on: May 22, 2013, 05:46:03 pm »
I don't want to be doing arch work. Can't decide if I like poke or not. I suppose its like marmite love it hate it mmmm!
Offline xjay1337
  • -Receive: 377
« Reply #7 on: May 22, 2013, 05:54:26 pm »
Honestly unless you have air and are prepared to ruin your arches you won't get 10s working.
You can't add enough camber to properly tuck the rear because the inside of the wheel/tyre will hit the strut.
And because of the width they will poke massively.
Further to that Falken only permit a 225/40 on a 9.5, I think on a 10 the smallest tyre you can use is a 235 which makes it pretty illegal in terms of, if you DID get pulled up on it..
In a word, no.
Offline Rob.
« Reply #8 on: May 22, 2013, 09:08:54 pm »
No such thing as "illegal" stretch (although you might attract unwanted attention from the boys in blue). You can have illegal amounts of rim poke (think it's 25 or 30mm outside of the arch, while the tyre tread itself has to be within the arch.
Offline tony_danza
  • -Receive: 112
« Reply #9 on: May 22, 2013, 09:15:27 pm »
Whilst it isn't illegal, you'd better be sending a picture of it to the insurance company to see if they're happy about it - because I know of at least 3 cases of people getting refused payouts following tyre failures and accidents.
Probably best for the showground only.
Sideways yo!
Offline Jabarton99
« Reply #10 on: May 22, 2013, 09:27:51 pm »
Thanks for all the advice, just going to try and mix and match and get a 8.5" rear which will be flush. Just going to cost a little more.
Offline Adriano
« Reply #11 on: May 22, 2013, 10:32:37 pm »
uk illegal streach ???
Offline Rob.
« Reply #12 on: May 22, 2013, 10:50:57 pm »
Offline Jabarton99
« Reply #13 on: May 22, 2013, 11:27:46 pm »
Thanks for the link, they look good. Think its a little to much poke for me though. I wonder how much that sort of poke would effect the handling. Just a thought as I love to drive the car, anyone know what effect it would have?
Offline Adriano
« Reply #14 on: May 23, 2013, 07:56:50 am »
sensitive steering and greater load bearing
