Author Topic: Tarox GT34 10Pot Calipers  (Read 1090 times)
Offline Jabarton99
« on: May 22, 2013, 05:15:48 pm »
Hi
I need some help, i have the above calipers on the front of my GTI and was wondering if anyone knows what's the max size disc the calipers will take. I think there 330mm at the moment but was wondering if they will take a bigger disc for eg:345/350mm disc
Any help is much appreciated.
J
R32 Recaro bucket seats (individual colour), Golf R MFSW with cream stitching, Cream stitched gear gaitor to match, RNS510, highline cluster, Ko4 turbo, Forge twintercooler, Forge oil catch can & washer bottle, Autotech fuel pump, Neuspeed power pully, S3 injectors, ITG maxogen intake, Red top coil packs, Milltek Full 3" exhaust straight through. AP Coilovers, H & R Anti roll bars, Tarox 10pot calipers front & S3 rear calipers rear.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Tarox GT34 10Pot Calipers
« Reply #1 on: May 22, 2013, 07:45:40 pm »
B34-GT10
    for road and racing use
    for discs 60mm deep
    extra hard grey anodised
    made from solid alloy billet
    multi piston seals allow for low maintenance
RECOMMENDED FOR
    Touring cars
    Road brake conversion kits
    Rally & GT cars
    Rear applications (smaller piston version)
TECHNICAL DETAILS
Piston number
Disc Ø (min-max)
Disc thickness (min-max)
Disc Depth
Weight
Mounting Type
Lug offset
Knockoff Piston
Minimum internal wheel Ø
Lug PCD
Mounting Centres
Piston Layout (Diameter in mm)
Total area (both sides) cm²
Pad Code
Pad Area
Pad Choice
Pad Thickness
Pad Depth
10
330-348mm
12-32mm
60mm
2.3kg
Lug
N/A
Optional
N/A
N/A
134mm
16/16/22/16/16
237
16/16/26/16/16
267
16/22/31/22/16
383
SP0239
80 cm²
.114/.501./116/.601
17mm
60mm
You would need new carriers also to accomodate the larger discs  :happy2:
« Last Edit: May 22, 2013, 07:54:44 pm by danishmkvgti »
Over the top mod list ;o)
