Author Topic: Part number  (Read 1175 times)
Offline Banham
  • GTI MK6
Part number
« on: May 23, 2013, 07:24:53 am »
Does anyone no the part number for headlight washer caps that go on the front bumper, which come out when the washers come on.
I need the smaller part of the two  :smiley:
Offline edd666999
  • -Receive: 89
Re: Part number
« Reply #1 on: May 23, 2013, 07:44:26 am »
Here we go Scott
Pump for headlight washers - 3B7 955 681 also N903 038 01 this is the O-ring for the pump
Gasket - 431 955 465A
Lift Cylinder - 1K6 955 978A x 2
Speed nuts - n909 591 01 x 4 - 2 per cylinder
Nozzle carrier Left - 1K6 955 103
"       "     "      Right - 1K6 955 104
Cover cap Left - 1K6 955 109 GRU
"          "    Right - 1K6 955 110 GRU
Adaptor - 1T0 955 665
Connector - 1J0 955 665E x 3
Hose in 10m length - 1J0 955 964F
Angled piece - 1J0 955 665A
Junction - 7L6 955 873
Terminals - 1J0 955 846 x 8
Cable tie with teminal socket - 3D0 971 838E x 1
If i've missed any thing ill add it later
By the way you may need this too,  its the water level for the washer bottle.
Water level switch  - 7M0 919 376
O ring - 7M0 919 382
Flat contact housing - 7M0 973 202
Darren
Is that any help?
Offline edd666999
  • -Receive: 89
Re: Part number
« Reply #2 on: May 23, 2013, 07:45:58 am »
actually:
Left = 1K0 807 717 B GRU
Right = 1K0 807 718 B GRU
This is for the primed version  :happy2:
Offline Banham
  • GTI MK6
Re: Part number
« Reply #3 on: May 23, 2013, 07:50:40 am »
actually:
Thanks alot  :happy2:
