Author Topic: Knocking noise - not just subframe spacer issue!  (Read 1183 times)
Offline AlexR
« on: May 23, 2013, 06:25:20 pm »
Hi folks, after some expertise if possible.
I have encountered the common 'clunk' noise when taking off/stopping sometimes. I'll hopefully sort that with the ECS spacer kit.
More importantly. Last week, there was another constant knocking noise. The noise comes about when I let off the accelerator or car is rolling in neutral. Approx 2000-3000rpm is at it's worst (sounds like something is knocking up and down off either the chassis or driveshaft or something!), and goes away instantly if I accelerate. Doesn't seem to occur under braking either. The noise is getting louder as the days go on.
Anyone experienced anything similar? Could it be engine/gearbox mounts?
Any help much appreciated as usual.
Offline AlexR
Re: Knocking noise - not just subframe spacer issue!
« Reply #1 on: May 24, 2013, 03:01:29 pm »
Problem is developing now. Clunking in the same way when changing into 2nd! Will try fitting the spacers and see what's what from there.
Any other ideas folks?
