Author Topic: ITG help!!!!  (Read 1645 times)
Offline 18Edition30
ITG help!!!!
« on: May 24, 2013, 06:32:26 pm »
Guys and girls
Fitted my ITG open induction kit a few nights back and getting on ok with it, not sure if I can live with darth vadar all the time though!
Anyway when stationary and I blip the throttle upto around 5k to show some people the noise it makes, when the revs drop back down to normal they go right down to 500rpm and engine nearly stalls then quickly jump back up to around 900rpm normal tickover, it never used to do this and I'm wondering what is happening? Obviously something to do with the kit.
Any ideas?
Will
Offline Jabarton99
Re: ITG help!!!!
« Reply #1 on: May 24, 2013, 07:18:09 pm »
When I got my ITG fitted it Iid the same. Took to the garge and it was my maf sensor due to increased air flow. So replaced it and all has Ben fine for 12months + now.
R32 Recaro bucket seats (individual colour), Golf R MFSW with cream stitching, Cream stitched gear gaitor to match, RNS510, highline cluster, Ko4 turbo, Forge twintercooler, Forge oil catch can & washer bottle, Autotech fuel pump, Neuspeed power pully, S3 injectors, ITG maxogen intake, Red top coil packs, Milltek Full 3" exhaust straight through. AP Coilovers, H & R Anti roll bars, Tarox 10pot calipers front & S3 rear calipers rear.
Offline 18Edition30
Re: ITG help!!!!
« Reply #2 on: May 24, 2013, 07:23:43 pm »
So could need new MAF sensor? How much are these?
What's the reason?
Will
Offline Jabarton99
Re: ITG help!!!!
« Reply #3 on: May 24, 2013, 07:44:44 pm »
Apparently they get dirty and when they have been on the car a while and you increase air flow they don't like it. It's not 100 % that but I bet you that's where a garage would start. There about £80 I think but it's been a while since mine was done. You can clean them but I beleive it's very tricky and doesn't always work.
Re: ITG help!!!!
« Reply #4 on: May 24, 2013, 07:46:18 pm »
Usually around £120-130...  :scared:
Offline 56OctyVRS
  • -Receive: 72
Re: ITG help!!!!
« Reply #5 on: May 25, 2013, 02:04:35 pm »
Try some electrical contact cleaner on the maf first.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: ITG help!!!!
« Reply #6 on: May 25, 2013, 05:59:06 pm »
X2 sound advice
It's about £5 from Maplins or Halfords. Remove the sensor from the housing, cover it in cleaner, leave it a short while to dry then try again. A lot cheaper than a new MAF.
Made my car a lot smoother after cleaning the MAF  :happy2:
Offline 18Edition30
Re: ITG help!!!!
« Reply #7 on: May 25, 2013, 08:54:03 pm »
So is this most probably the problem then?
Will try tomorrow.
Offline edd666999
  • -Receive: 89
Re: ITG help!!!!
« Reply #8 on: May 26, 2013, 02:45:42 pm »
Cleaned mine with the halfords stuff £3.99. Didn't however fix my issue lol.
Offline Marshall
Re: ITG help!!!!
« Reply #9 on: May 26, 2013, 03:00:50 pm »
If the car was ok beforehand I think I'd be checking the pipe on to the turbo to make sure its seated properly.
This sounds more like unmetered air getting in through a leak after the maf.
I'd check that when the clip has been tightened on to the turbo it hasn't ridden up on one side.
Also check maf is securely fitted, I'm pretty sure they only fit one way.
MISANO RED RS3
Offline RedED30
  • -Given: 19
Re: ITG help!!!!
« Reply #10 on: May 26, 2013, 04:20:22 pm »
Agree with all of this. i'd be checking everything is seated 100% and cleaning the maf before shelling out for new one.
Revo Stage2 - With Linear Throttle
Revo DSG
BCS Turboback Powervalve - This is a must.
ITG Closed Intake.. wooosh
Here to enjoy and help, with a hint of sarcasm, please do not be offended
Offline 56OctyVRS
  • -Receive: 72
Re: ITG help!!!!
« Reply #11 on: May 26, 2013, 10:25:13 pm »
Also make sure the seal that fits between the maf and intake is fitted also.
Offline 18Edition30
Re: ITG help!!!!
« Reply #12 on: May 27, 2013, 05:28:46 pm »
X2 sound advice
Just spray on and leave to dry?
Don't wipe with cloth or anything no?
And you mean on the actual MAF itself don't you?,, not the electrical points lol.
Sorry for the silly questions.
Cheers again
Offline edd666999
  • -Receive: 89
Re: ITG help!!!!
« Reply #13 on: May 27, 2013, 05:36:11 pm »
X2 sound advice
Cheers again
you can spray it on both providing its electrical contact cleaner
