Author Topic: Throttle body????  (Read 11729 times)
Offline gazbutS3
Throttle body????
« on: May 27, 2013, 07:20:38 pm »
After 5 years pretty much trouble free, considering the stick its gets, motoring had an ECL today declaring a traction control issue, went home and did a scan and got the following
Monday,27,May,2013,13:23:33:23089
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 77
VIN: WAUZZZ8P38A198451   Mileage: 70980km/44104miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 8P0 907 115 H    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0050
   Revision: 5BH16---    Serial number: AUX7Z0H3FNU09O
   Coding: 01030003180F0060
   Shop #: WSC 13879 664 427782
   VCID: 37763BE34617B5A0D06
5 Faults Found:
000291 - Throttle Position Sensor (G69)
               P0123 - 001 - Signal too High
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 70981 km
                    Time Indication: 0
                    Date: 2013.05.27
                    Time: 13:15:53
             Freeze Frame:
                    RPM: 3992 /min
                    Load: 45.1 %
                    Speed: 62.0 km/h
                    Temperature: 81.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
008482 - Accelerator Position Sensor (G79)
               P2122 - 002 - Signal too Low
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 70981 km
                    Time Indication: 0
                    Date: 2013.05.27
                    Time: 13:15:53
             Freeze Frame:
                    RPM: 3992 /min
                    Load: 39.6 %
                    Speed: 62.0 km/h
                    Temperature: 81.0°C
                    Temperature: 25.0°C
                    Voltage: 13.716 V
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 70981 km
                    Time Indication: 0
                    Date: 2013.05.27
                    Time: 13:15:53
             Freeze Frame:
                    RPM: 4445 /min
                    Load: 50.6 %
                    Speed: 61.0 km/h
                    Temperature: 81.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
001688 - Sensor Reference Voltage C
               P0698 - 002 - Too Low
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 70981 km
                    Time Indication: 0
                    Date: 2013.05.27
                    Time: 13:15:53
             Freeze Frame:
                    RPM: 4367 /min
                    Load: 48.6 %
                    Speed: 60.0 km/h
                    Temperature: 81.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
005445 - Throttle Valve Controller
               P1545 - 008 - Malfunction
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 70982 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
                    Temperature: 26.0°C
                    Voltage: 13.081 V
Readiness: 0000 0100
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004744
   Shop #: WSC 06314 000 00000
   VCID: 72E0CAF76DF51088278
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
did a fault code reset and everything was fine for 10 miles or so, but when I made some progress again, the car went into limp mode and wouldn't do more than 20mph, are the faults connected and do you think it looks like another throttle body victim?????
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ebascp21af9pec5kmqpjrku4kf&/topic,19740.0.html
Re: Throttle body????
« Reply #1 on: May 27, 2013, 08:13:12 pm »
Yep.... Looks like another one bites the dust!  :sick:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #2 on: May 27, 2013, 08:29:27 pm »
as you might know i chewed my way through about 5 Throttlebodies, it only ended when i changed the wiring (i changed the complete wiring not only to the TB) actually the wiring is cheaper that the TB's by about 40 percent. Brian at BNAutoteknik has just fitted my last faulty revision Q TB on a 500bhp Cupra and so far it works perfectly even though i got the same faults as you  :stupid:
Over the top mod list ;o)
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: May 27, 2013, 08:33:16 pm »
Shows that your issue was deffo the wiring.
I'm 100% sure all these recent ones have actually been the tb.
Follow AKS tuning on Facebook
« Reply #4 on: May 27, 2013, 08:37:52 pm »
Mine was the TB... cant be the wiring as the fault has not returned since. ( same with Chungster and the other 13)  :grin:
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: May 27, 2013, 08:39:56 pm »
I think gaz makes it 16 total now.   :signLOL:
Time to write some letters to vag me thinks.
« Reply #6 on: May 27, 2013, 08:44:36 pm »
Get me a refund plz?  :grin:
Offline gazbutS3
« Reply #7 on: May 27, 2013, 08:48:11 pm »
so is the traction fault code linked to the TB problem?
  • -Given: 243
  • -Receive: 154
« Reply #8 on: May 27, 2013, 08:50:53 pm »
I thought the same, but the fault kept comming on the new ones i fitted after different time periods, not that i say it's deffo the wiring, just saying that there might be other reasons for the faults  :happy2:
« Reply #9 on: May 27, 2013, 08:51:05 pm »
Yep... same errors i had... ECL and ESP light on.
Is stores....
   Revision: 00H13001
   Coding: 0004744
1 Fault Found:
... as the result of the TB sensor error... no actual ABS issue.
Saintsteve
« Reply #10 on: May 27, 2013, 08:52:21 pm »
Something simular to the TT mk2 owners with their failing window regulators?? :signLOL:   :notworthy:
Offline gazbutS3
« Reply #11 on: May 27, 2013, 09:08:10 pm »
Is stores....
   Revision: 00H13001
   Coding: 0004744
1 Fault Found:
ah very interesting :happy2:
so what are the costs involved replacing the TB?
« Reply #12 on: May 27, 2013, 09:14:02 pm »
Alex did mine... just under 400 supply and fit.
IIRC Alex said that the part from VW dealers is over 400  :surprised:
Offline gazbutS3
« Reply #13 on: May 27, 2013, 09:17:03 pm »
next question is how do I get it to Alex???, anybody know any good car transporters?
Offline Jussa
  • Bicester
« Reply #14 on: May 27, 2013, 09:36:31 pm »
I hope u get it sorted Gaz  :happy2:
