Author Topic: Battery Drain, just fitted Alpine headunit  (Read 1207 times)
Offline Scaff
« on: May 28, 2013, 06:02:29 pm »
I need some help, I just fitted an alpine head unit to replace my mfd2 and no matter how I wired it, it has a constant live and is draining the battery after 1-2 days. I've read about the canbus gateway needing to be updated for the rns510 but wasn't sure if that was the problem I had here. appreciate any help
The stereo is a Alpine IDA-X100 and its a 2006 golf gti
cheers
Offline skard
  • -Receive: 245
Re: Battery Drain, just fitted Alpine headunit
« Reply #1 on: May 28, 2013, 06:08:00 pm »
Different problem to factory HU's.
There is no native switched live in the OEM loom, so you need to take a switched live feed to your Alpine loom from elsewhere (drivers fusebox is best). Or buy a CAN adaptor box fromthe likes of Connect2 which tells your aftermarket stereo to shutdown on ignition off.
Offline Scaff
« Reply #2 on: May 28, 2013, 06:41:55 pm »
Thanks mate, I'll go for the live feed from the fusebox then
Offline skard
  • -Receive: 245
« Reply #3 on: May 28, 2013, 07:44:45 pm »
No probs, should be a quick and easy fix.
Seach for 'Add a circuit', items such as 180735526749 come up, and these take 5 minutes to fit nce you run some wire from the HU loom.
Best using a multimeter to find a switched live first if buying these, as there is a mixture of mini blade and normal blade fuses in that compartment - so you'd want to buy the right sized one.
