September 23, 2024, 03:29:36 pm
All Things Mk5
Mk5 General Area
Picture request for all those with 2008MY GTI's......
Topic: Picture request for all those with 2008MY GTI's...... (Read 1461 times)
WhiteGTI
Just look at my post count
-Given: 29
-Receive: 22
F-A-S-T
August 08, 2009, 03:15:31 pm »
Can you go and take a photograph of the gear shifters, located on top of the gearbox in the engine bay? An aerial shot will be perfect, like the pic below. Ignore my writing...
It seems that mine is different to the others, with regard to the clips used.
Many thanks in advance!!!
2006 E46 BMW M3 - 343hp
Janner_Sy
-Given: 62
-Receive: 113
Re: Picture request for all those with 2008MY GTI's......
Reply #1 on:
August 08, 2009, 04:56:51 pm »
not sure what mine is but that is exactly the same. all i did to remove the side shift was pull it aside, slot a pair of long nose pliers behind it and lever it out
the bit below the gear shift wasnt even touched when i changed my gear shift to the forge one
WhiteGTI
-Given: 29
-Receive: 22
F-A-S-T
Reply #2 on:
August 08, 2009, 05:00:48 pm »
Ahh ok Simon, so like me, you don't have a C clip on the shifter cable that sits Vertically? (on the right of the picture)
And on the pivot shaft (in the centre of the picture), like me, you don't have the C clip either?
MAT ED30
-Given: 25
-Receive: 82
Vwr fan boy
Reply #3 on:
August 08, 2009, 10:56:49 pm »
That's the same as what mine was like but mine's all changed now to the early style metal side to side as that's what works with short shifters
Last Edit: August 08, 2009, 11:09:02 pm by MAT ED30
WhiteGTI
-Given: 29
-Receive: 22
F-A-S-T
Reply #4 on:
August 08, 2009, 11:00:22 pm »
Thanks Mat!
So they changed it to my set-up for 08MY, then changed it back again afterwards?
All Things Mk5
Mk5 General Area
