Author Topic: how to turn indicators on front on as side lights  (Read 12104 times)
Offline gjseb16
« on: May 31, 2013, 10:17:28 pm »
as above guys been searching seen a few cars that have had this done where they using the front indcators as like side lights unless i am wrong how is this done is it easy enough to do
Offline SI-R32
  • -Receive: 126
Re: Re: how to turn indicators on front on as side lights
« Reply #1 on: May 31, 2013, 10:20:34 pm »
You just need vcds, go into central electrics and its in there, you can have any brightness you wish on then,  you just put in a value, I have mine on 75 percent
Offline Steviedubs
« Reply #2 on: May 31, 2013, 10:26:00 pm »
VAGCOM address 09 central electrics , long coding, long coding helper, turn signal as running light and type in a value between 0-100 this is for the brightness. I have mine at 20% and is a good brightness
Offline gjseb16
« Reply #3 on: May 31, 2013, 10:27:42 pm »
bloody hell i need to get my self a vagcom lead or something i want this doing but no one local to me to sort also whats this corning lights all about can these be turned on via vagcom lead of like ebay and how easily is to be done
Offline Steviedubs
« Reply #4 on: May 31, 2013, 10:29:52 pm »
Cornering lights I assume you mean the fog lights as cornering lights? Iirc you will need a new 30 byte highline CECM.
Where are you? Near Bradford?
Offline gjseb16
« Reply #5 on: May 31, 2013, 10:32:16 pm »
which i have got highline display, no i am not i am in skegness but got family in wakefield and go up there quite alot i so want this doing despratley sound like a little kid a christmas but looks so good
Offline Steviedubs
« Reply #6 on: May 31, 2013, 10:35:11 pm »
Your confusing the highline display in your instrument cluster with the 30 byte highline central electrics module which you'll need. I doubt you'll have the the 30 byte CECM.
If your ever in the area give me a shout on here and I'll happily do the lights for you.
Offline rf860
« Reply #7 on: May 31, 2013, 10:51:46 pm »
My ed30 has cornering fogs?
Offline Jonny
  • G7R Owner
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,45008.0.html
« Reply #8 on: May 31, 2013, 11:15:50 pm »
It all depends on what cecm you've got. If you have a 30 byte one then yes, you just need to activate it via vcds  :happy2:
Offline rf860
« Reply #9 on: May 31, 2013, 11:17:30 pm »
So does this mean my car has features that could be turned on?
Offline xjay1337
  • -Receive: 377
« Reply #10 on: June 01, 2013, 12:46:06 am »
Like this?  :grin:
As said you use VCDS in 09-> coding -> long coding helper -> turn signal as running light
You don't need a fancy CECM for that but you do for the cornering fogs (Just clarifying).
ps on a personal note I think cornering fogs look daft  :scared: :P
Offline rf860
« Reply #11 on: June 01, 2013, 09:55:36 am »
Like this?  :grin:
Do you know what else i could do? Just cooool features and that?
NO! Cornering fogs are a great idea lol....
Offline dmac1969
  • -Receive: 21
« Reply #12 on: June 01, 2013, 08:33:55 pm »
I had no idea you could do that with the indicators! Looks great IMHO , I wouldnt mind that done on mine....
Offline gjseb16
« Reply #13 on: June 01, 2013, 08:37:00 pm »
I want mine doing to but no one local to me I wish I was not living in sticks does my head in
« Reply #14 on: June 01, 2013, 09:53:40 pm »
Tom in Lincoln could do it  :happy2:
