Author Topic: Cdl engine swap  (Read 14080 times)
Offline pd9264
Cdl engine swap
« on: June 01, 2013, 08:41:23 am »
Will a cdl engine which used to have a dsg box on it fit in my mk5 gti with my manual box bolted on. In the process of getting one but  just want to be sure it's ok.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Cdl engine swap
« Reply #1 on: June 01, 2013, 09:29:19 am »
Yes matey, it sure will... Just make sure you get it mapped to suit, Right away!  :happy2:
Silver is the way !
Offline james
Re: Cdl engine swap
« Reply #2 on: June 01, 2013, 11:10:33 am »
100% fine   just use your fuel pressure sensor and map sensor.
Offline pd9264
Re: Cdl engine swap
« Reply #3 on: June 01, 2013, 02:49:27 pm »
Cheers for the help peeps. I'm running stage 3 on my old bwa at the moment. Will I still need the map adjusted.
Offline GarethB
Re: Cdl engine swap
« Reply #4 on: June 01, 2013, 05:59:01 pm »
Any specific reason for going CDL?
Problems with the BWA? Desire to push things further?
Re: Cdl engine swap
« Reply #5 on: June 01, 2013, 07:00:43 pm »
I think this may have something to do with his desire...
http://www.mk5golfgti.co.uk/forum/index.php/topic,66800.0.html
Offline GarethB
Re: Cdl engine swap
« Reply #6 on: June 01, 2013, 08:29:52 pm »
I remember reading this thread a while back  :sad1: - didn't link the OPs were the same.
Hope the OPs probs are resolved quickly & trouble free.
Offline james
Re: Cdl engine swap
« Reply #7 on: June 02, 2013, 05:25:36 am »
it will need to be tweaked as different compression ratio, but your get more power out of it.
I changed from a bwa to a cdl.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Cdl engine swap
« Reply #8 on: June 02, 2013, 05:34:12 am »
You may have problems along the way but put it all down to experience... You will learn a lot, and what a journey!
Good luck!
You will never look back  :wink: or maybe you will but soon to realise you made the right choice.!
 :jumpmove: :jumpmove: :jumpmove: :jumpmove: :jumpmove: :jumpmove:
Silver is the way !
Offline pd9264
Re: Cdl engine swap
« Reply #9 on: June 02, 2013, 10:48:41 am »
Yeah that's the reason for going cdl
As I smoked my my last engine through a stupid mistake. It threw about 6 of the rockers off which jammed th valves so that bent them. And also jammed the intake cam which in turn snapped the sprocket of the exhaust cam at th cam chain end. Oh and blew a couple of holes in the intake.  So well in truly stuffed it.
Offline pd9264
Re: Cdl engine swap
« Reply #10 on: June 02, 2013, 12:24:09 pm »
She's out
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Cdl engine swap
« Reply #11 on: June 02, 2013, 07:57:25 pm »
good job dude, you doing it at home on your own?
Silver is the way !
Offline pd9264
Re: Cdl engine swap
« Reply #12 on: June 02, 2013, 08:48:44 pm »
Yeah I thought I would have a go. It doesn't seem that bad. Took 4 hours to get to that stage. Getting my new engine on wendsday. So il transfer all my parts and fit the new one on Saturday. I'm debating wether to stick a new helix clutch in though as seen as its out it would take minutes. But it's more expense.  The new motor is from a tts same as s3 so I'm hoping it will be ok. It comes with a clutch on it anyway but I don't no if there a stronger clutch than my standard bwa one or the same.
Offline pd9264
Re: Cdl engine swap
« Reply #13 on: June 02, 2013, 09:07:00 pm »
Some pics
Of
The damage done to old engine. Snapped sprocket of exhaust cam at cam chain end. Also 2 bent intake valves.
Could of been repaired  but thought may as well go the whole way.
« Last Edit: June 02, 2013, 09:12:03 pm by pd9264 »
Offline vRSAlex
  • -Receive: 253
Re: Cdl engine swap
« Reply #14 on: June 02, 2013, 09:13:29 pm »
Snapped the top of the valve off too!
Good effort.
Follow AKS tuning on Facebook
