Author Topic: Mk6 flat bottom steering wheel  (Read 4782 times)
Offline curley
Re: Mk6 flat bottom steering wheel
« Reply #15 on: August 14, 2009, 06:33:30 pm »
Well done that man. It does look great much better than before.
Offline ollie288
« Reply #16 on: August 14, 2009, 07:47:02 pm »
Thanks :happy2: I cant wait to get it fitted!
« Last Edit: August 14, 2009, 08:17:03 pm by ollie288 »
Offline x5pea
« Reply #17 on: August 15, 2009, 10:23:27 pm »
you can get these on ebay for around £400, they arent mk6 GTI ones tho, most likely from the new passat cc or scirocco but essentially they look the same. GTI has red stitching and i think is only orderable if you have a GTI
Offline mortygttdi
  • -Receive: 146
« Reply #18 on: August 15, 2009, 11:01:21 pm »
Mk6 GTD has the same wheel infact the only thigs it hasn't got over the gti is the wheels, exhausts and engine :confused: every thing else is GTI spec.
Offline winrya
« Reply #19 on: August 16, 2009, 09:06:19 am »
Can't remember if it was evo mag or top gear but they said it has different suspension setup and as such doesn't drive anywhere near as well as the gti
