Author Topic: Which big brake kits fit behind Pescaras?  (Read 10614 times)
Re: Which big brake kits fit behind Pescaras?
« Reply #15 on: June 11, 2013, 03:07:30 pm »
Smallish spacers will be fine on the fronts as you have adjustable top mounts with the Clubsports. For a track/road set-up you would have about 3 degrees of camber which will get you peskis and a spacer well tucked under out of the way.
As you mentioned the Tarox will stop you on a penny but they are very expensive for disc's. I would go for the Alcon set up! as an allround compromise it meets most of your requirements best, Unless DaveB can cobble you some magic from somewhere.  :happy2:
« Reply #16 on: June 11, 2013, 09:10:05 pm »
A chap called GTI_James had Stoptech on his Ed30.  :happy2:
Offline Dario
  • booosting... :)
« Reply #17 on: June 12, 2013, 02:07:15 am »
i have them also,very good kit ,but they cant fit without a 12mm spacer in front
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #18 on: June 23, 2013, 07:29:40 pm »
The ap 4 pots will fit behind the oem pescaras with 3mm - 4mm clearance, obviously r32 brakes will fit aswell.
MK7 GTI - ARRIVING DECEMBER
Offline spb
« Reply #19 on: July 04, 2013, 08:23:25 am »
Such a kit is quoted on the web at almost 2000GBP :(
Any other choices for a good brake upgrade kit that will fit behind Pescara without spacers? Alcon, Willwood, Movit...?
« Last Edit: July 04, 2013, 08:28:36 am by spb »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #20 on: July 04, 2013, 10:53:33 am »
No, you need Team Dynamics Pro Race 1.2 or equivalent to fit calipers with pistons on the outside of the disc except the Tarox 10 pot solution  :happy2:
Over the top mod list ;o)
Offline spb
« Reply #21 on: July 04, 2013, 01:09:30 pm »
Unfortunately still in the 2k GBP area :). And most likely you sold yours so no 2nd hand alternative :)
  • -Given: 243
  • -Receive: 154
« Reply #22 on: July 04, 2013, 03:24:33 pm »
My Tarox is gone for the amount of 470£  :stupid:
Offline spb
« Reply #23 on: July 05, 2013, 02:14:51 pm »
Very good price but now it's too late for that.
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #24 on: July 05, 2013, 03:04:42 pm »
As you mentioned the Tarox will stop you on a penny but they are very expensive for disc's. I would go for the Alcon set up! as an allround compromise it meets most of your requirements best, Unless DaveB can cobble you some magic from somewhere:happy2:
Got a brand new AP Racing 330mm kit with CP5200 calipers - Thonk its CP5200-156 for the GTI uses the evergreen CP3215-D50 pad its basically the same caliper in terms of piston sizes and design as the CP5040 Pro 5000 race caliper I think its 1,5mm wider from the centreline to the front face.
Retail is £1638 plus VAT with a 8 week lead time, looking for £1480 all in delivered. Andy (Wigit) had the last one and gave some good feedback following a track day he did
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #25 on: September 14, 2013, 08:46:20 pm »
Swap the Pescaras for the same style but ET44 BBS VZ033s. Much better clearence.
"You get what you pay for."
Offline spb
« Reply #26 on: July 12, 2015, 02:19:02 pm »
With et 44 will they rub?
Sent from my SM-N910F using Tapatalk
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #27 on: September 02, 2015, 05:17:16 pm »
Usually ET44/45 won't rub, but it depends on your choice of tyres.
Do the fender screw mod and 95 % of 225s will never rub, while all
235 semi-slicks (which tend to be wider) will certainly rub even with
the mentioned screw removed. Nevertheless 8x18 ET45 is a highly,
if not the most popular size.
