Author Topic: Problem with Xenon highlights  (Read 826 times)
Offline Kiwi
« on: June 02, 2013, 09:04:22 pm »
Got a Xenon fault,
1 Fault Found:
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
            010 - Open or Short to Plus
Can I buy the Adjusting motor ?
Has anyone else had this problem before?
Offline SI-R32
  • -Receive: 125
Offline Kiwi
Re: Problem with Xenon highlights
« Reply #2 on: June 02, 2013, 09:43:19 pm »
yes you can its about 75 quid from vw
4B0941293A
https://www.google.co.uk/search?q=4B0941293A&safe=off&source=lnms&tbm=isch&sa=X&ei=s6mrUYysHcmBOI-dgYAI&ved=0CAcQ_AUoAQ&biw=1304&bih=707
Thanks Bud,
That is a great help. I just need to work out, where and how to take the light apart, to be able to replace motor.
Does anyone, know if you can do it while the light is in place ???
