Author Topic: Help with HID'S AND BATTERY  (Read 1070 times)
Offline blacklabeluk
« on: June 03, 2013, 10:09:35 am »
Hi
Cars been in the garage all week.
i get it back last night to install my new HID kit
http://www.ebay.co.uk/itm/390581231157?var=660127376093&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
all plug and play, working fine for around 10 minutes sat on the drive. but then the lights start flickering the hid's and the led number plate lights so i disconnect and turn off.
get back in my car and the car is completely dead?
any ideas what this could be ?
Offline DDM
Re: Help with HID'S AND BATTERY
« Reply #1 on: June 03, 2013, 10:48:13 pm »
did you have it running whilst it was sat there, if not i presume you've flattened the battery with just the ignition  and lights on.
Offline jonnym
  • -Given: 40
« Reply #2 on: June 03, 2013, 10:52:29 pm »
This. Numberplate leds and your hids won't both be linked up together (apart from the common power source), so mroe than likely be running the battery down. Maybe check your fuses aswell just for piece of mind.
Offline SI-R32
  • -Receive: 125
« Reply #3 on: June 04, 2013, 05:47:53 am »
As said above sounds like you didn't have your engine running, all can bus friendly bulb kits of any kind need to replicate the current drawn by the original bulb, as your headlights are 55w each i would imagine in the ballast (black box) there is a resistor to pull about 4 amps times this by 2 for each head light, add the other current for running the hid's times this by 10 mins of running ie say 12 amps being pulled from the battery then the car will either start turning things off due to the battery getting to low or your battery is on its way out and can't supply 12 amps or so for 10 mins
if you had your car running then clearly this should never have happened, so if it was running did you get any bulb out warnings coming up on the dash display? as if the correct current is not being replicated on the circuit the CECM will turn off the power to each device, but as also previously stated the number plate lights have no connection to the headlights.
« Reply #4 on: June 04, 2013, 03:30:40 pm »
thanks for the help,
still not starting!
figured it must be the battery so changed the battery and it still didn't start.
so i got a mate to plug it in and it came up saying there was an error with the 'fuel pressure regulator'
e cancelled the error and it started for 5 mins then cut out, we plugged it in again and it wouldnt let me cancel the error.
any ideas?? ive got a number for someone to come out with a proper vagcom is it worth ringing him?
thanks again
Offline edd666999
  • -Receive: 89
« Reply #5 on: June 04, 2013, 04:08:19 pm »
Maybe you caught and damaged the sensor on top of the fuel pump?
Offline xjay1337
  • -Receive: 377
« Reply #6 on: June 04, 2013, 05:28:43 pm »
Try removing the HIDs... You might be surprised.
« Reply #7 on: June 04, 2013, 10:20:51 pm »
thanks,
where is the fuel pump located though?
thanks
Offline DDM
« Reply #8 on: June 05, 2013, 03:07:16 pm »
is it possible you've fried something with it sat there with just the ignition on?
« Reply #9 on: June 05, 2013, 11:01:33 pm »
BUMP
« Reply #10 on: June 07, 2013, 12:43:38 am »
Sorted, so many errors on the vagcom!
Cleared them all started first time!
« Reply #11 on: June 07, 2013, 07:44:59 am »
glad you got it sorted
Offline DBILAS
« Reply #12 on: June 07, 2013, 05:53:17 pm »
thats good
