Author Topic: all I did was change spark plugs  (Read 7107 times)
Offline edd666999
  • -Receive: 89
« on: June 03, 2013, 03:38:14 pm »
So alex sent me some new spark plugs.
Thought I'd change them, as I have done before.
Battery off
Airbox off
Coilpacks out
Spark plugs out
Then reverse.
Now if I go anywhere near 5000rpm whether that be a wot or very slowly the revs just drop and I get no go until I take my foot off the accelerator.
I have swapped spark plugs back and same issue.
No fault code.
Have I damaged something?  Maybe coil pack? Every time its been a coil pack before I have had eml and a code and its been down to how much power I apply not revs.
Offline 56OctyVRS
  • -Receive: 72
Re: all I did was change spark plugs
« Reply #1 on: June 03, 2013, 04:18:43 pm »
Id just re check everything. Make sure the maf is plugged in. The Coil packs are firmly pressed onto the plug. The loom is clipped onto each coil pack correctly. The plugs are correctly torqued up to 21lbs. Much more than that there isn't a lot that can go wrong.
Have the plugs come pre-gapped or do they need altering to suit?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: June 03, 2013, 04:37:37 pm »
I'm assuming you bought some D4YS, if so, what do you have them gapped to?
Offline edd666999
  • -Receive: 89
« Reply #3 on: June 03, 2013, 05:21:38 pm »
Alex gapped and lubed them.
But I have gone back to standard plugs with same issue.
I don't have a torque wrench so just made them tight. Woukd this issue be caused by them not being tight enough?
Offline dokez
« Reply #4 on: June 03, 2013, 06:11:58 pm »
Should just be hand tight with proberly a 1/4 turn afterwards.
Have you logged them car then to see what its failing on?
Offline chungster
« Reply #5 on: June 03, 2013, 07:02:00 pm »
Have you dropped anything into the turbo intake tube or into the air box?
I had a similar problem years ago on a 1.8T motor - found out we blocked the cold air feed so it wasn't picking up enough air for it to rev!
Offline edd666999
  • -Receive: 89
« Reply #6 on: June 03, 2013, 08:30:09 pm »
Im using the standard air intake, which I have only been using a few days. Cant see it being blocked but ill look.
Offline dokez
« Reply #7 on: June 03, 2013, 11:03:04 pm »
try disconnecting the battery again for 5 minutes, reconnect back up. (positive)
« Reply #8 on: June 03, 2013, 11:39:02 pm »
Ed I seem to recall you have an APR map so double check that you haven't switched into valet mode (assuming that mode is in your map).
Offline edd666999
  • -Receive: 89
« Reply #9 on: June 04, 2013, 07:28:47 am »
I was thinking that but have you seen the procedure to change to valet mode? It's easier to send a man to the moon!
I'll do battery and check the map mode this morning, I have a new maf and some coil packs waiting my collection at tps too.
« Reply #10 on: June 04, 2013, 07:37:27 am »
if you disconnect your battery will you loose the settings for the map and revert back to basic settings like revo does
Offline edd666999
  • -Receive: 89
« Reply #11 on: June 04, 2013, 07:50:30 am »
You don't, apr stays the same. I asked that direct question when having it fitted. Plus you use the cruise control stalk to change maps and every time I disconnected the battery it stayed on the 3flashes map....thank god.
« Reply #12 on: June 04, 2013, 08:16:53 am »
I must admit I don't know the technical procedure but if the ecu isn't locked out then the map can actually change whilst driving as seen in many cases in the US.
Hope you get it sorted asap whatever the reason.   :smiley:
Offline edd666999
  • -Receive: 89
« Reply #13 on: June 04, 2013, 08:19:35 am »
I'm so close to having a issue free car! I can feel it.
Offline edd666999
  • -Receive: 89
« Reply #14 on: June 04, 2013, 01:14:24 pm »
Map fine, 4new coil packs, new plugs, new maf.
Issue still there. Booked in at awesome before I smash the car up
