Author Topic: all I did was change spark plugs  (Read 7072 times)
Offline Jussa
  • Bicester
Re: all I did was change spark plugs
« Reply #15 on: June 04, 2013, 06:11:45 pm »
Map fine, 4new coil packs, new plugs, new maf.
Issue still there. Booked in at awesome before I smash the car up
 :signLOL: I know how u feel - I feel the same when anything of mine doesn't work correctly either!!
BTW I don't think Revo settings go back to stock if the battery is disconnected??
Offline edd666999
  • -Receive: 89
« Reply #16 on: June 04, 2013, 07:20:15 pm »
Revo does apr doesn't
Offline Jussa
  • Bicester
« Reply #17 on: June 04, 2013, 07:30:00 pm »
My battery was disconnected on Thursday at AKS, I even got a call from tracker, but my settings never went back to standard - I'm Revo stage 2+   :confused:
Offline detailer
  • I like things shiney
« Reply #18 on: June 04, 2013, 07:32:04 pm »
Not having any luck are you mate  :scared: sure awesome will sort it.
Offline Itsagthing
« Reply #19 on: June 04, 2013, 10:53:20 pm »
Who on earth told or taught you too disconnect the battery when changing spark plugs? Sounds like something my apprentice would do.
Offline Jussa
  • Bicester
« Reply #20 on: June 04, 2013, 10:57:45 pm »
 :signLOL:
« Reply #21 on: June 04, 2013, 11:19:40 pm »
Ok, he's fired...   :laugh:
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #22 on: June 05, 2013, 12:11:49 am »
 :signLOL:
Did he put his warning triangle out on the drive too?!
Chad Valley 'My First Socket Set' perhaps?
Won't be doing that again after the invoice that's coming.....
Offline edd666999
  • -Receive: 89
« Reply #23 on: June 05, 2013, 08:25:22 am »
Oh so disconnecting the battery caused this issue?
That's funny because it didn't cause it the other 3times I swapped plugs. ..or the time I replaced the battery for a new one
Take your sarcastic comments elsewhere. We cant all be wonderful vw techs because we all know how great they are.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #24 on: June 05, 2013, 10:05:24 am »
Have you checked nothing went down your turbo pipe?  Bit of a pita to get the clamp off. A torch and some long thin tongs might be handy.
VCDS scan whilst running to 5k should show if you have a timing, misfire, fuel pump, etc. matter.
My old stage 2 map would feel like it was pulling back around 5k, changed maps and it was all good.
Hope you get to the bottom of it at Awesome. :happy2:
Offline edd666999
  • -Receive: 89
« Reply #25 on: June 05, 2013, 02:50:58 pm »
Tbh im off work, the sun is out and all I want to do is chill out so I'll pay awesome to log.
I did have a good look into the turbo and couldnt see anything
Offline Itsagthing
« Reply #26 on: June 05, 2013, 05:30:25 pm »
No sarcasm I simply asked who told you that? No where in my wording was anything saying disconnecting the battery caused this! There's just no need to do it too change over plugs. Take the pill of chill ness mate!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #27 on: June 05, 2013, 07:27:46 pm »
 :signLOL:  Can't blame you there!  Lovely weather atm... touch wood.
Offline Sie
« Reply #28 on: June 11, 2013, 07:10:29 am »
Did you sort this? What was it?
Simon
Fettled Laser Blue '05 GTi 5dr
« Reply #29 on: June 11, 2013, 07:14:37 am »
did this get sorted out in the end
