Author Topic: all I did was change spark plugs  (Read 7070 times)
Re: all I did was change spark plugs
« Reply #30 on: June 11, 2013, 08:18:09 am »
did this get sorted out in the end
iirc he's booked into Awesome today for troubleshooting.
Offline edd666999
  • -Receive: 89
« Reply #31 on: June 11, 2013, 04:35:04 pm »
The problem just disappeared. Cant get it to do it anymore.
Awesome looked at the car and cleaned the pcv valve as they thought that might be causing my uneven idle.
Has anyone seen the latest version of the pcv valve? £100 and replaces the bit at the front and the rear bit going to the turbo?
Offline flatout
« Reply #32 on: June 14, 2013, 06:58:54 pm »
if you disconnect your battery will you loose the settings for the map and revert back to basic settings like revo does
i bought my car with revo stage 2 and had battery disconected,so does that mean my car isnt running the stage 2 map anymore then??
stage 2+ Grey Ed30..DSG 362 BHP.380 lb/ft.....Also Statller Tuned :)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #33 on: June 14, 2013, 07:02:48 pm »
If its been disconnected for a couple of hours or more then it will have reverted to stock settings.
However the map is still there you just need someone with a Revo SPS switch to put the settings back on.
Offline flatout
« Reply #34 on: June 14, 2013, 07:06:43 pm »
yeah it wo bout 3-4 hours,what a bugger,i thought it wasnt as quick as before.........anybody got a switch pppplllleeeeaaaaassssssseeeeeeeee??????
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #35 on: June 14, 2013, 07:09:04 pm »
I have but I'm on holiday. I'm in North Yorkshire when I get back. Where are you?
Offline flatout
« Reply #36 on: June 14, 2013, 07:12:33 pm »
have ya...brilliant,,im in rotherham south yorkshire,
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #37 on: June 14, 2013, 07:29:13 pm »
I'll be back last week June (after 24th) so give me a shout then and I'll put the settings back.
Not sure if my switch will work as its for a 2.0TSi but it should do. If not ill try it plugged in to the laptop and go through the Revo SPS software. Do you know what the settings where before? Boost 7, Timing 6, Fuel 8 for example. If not we may need to do a bit of data logging to get safe settings.
Offline flatout
« Reply #38 on: June 14, 2013, 08:31:20 pm »
brilliant thank you,i dont know the settings no...is it safe to drive then on the basic settings its not guna blow up or owt stupid lol,ive driven it for about 6 week like this,not really gave it beans or owt,its booked in at r-tech in 6 weeks time for a custom map,u reckon it will be ok till then??
Offline edd666999
  • -Receive: 89
« Reply #39 on: June 14, 2013, 08:58:51 pm »
perfectly fine its the same map just timing is 0, boost is 1 and fuel is 0. just means less go
« Reply #40 on: June 14, 2013, 09:55:25 pm »
Oh where about you on your hols
