I've always wondered what the ECON button did. I have been using it as this: push it (light comes on) and car gets colder. Press the button to turn the light off and car gets warmer.
After a little research I discovered that the car always has Air-Con on unless you press the ECON button. But here is where I am confused; When the light is illuminated on the button, the blowers blow out colder air, when according to everything I've read, the opposite should be true.
When I use it I turn the heater controls all the way down to LO then press the button to make the light illuminate.
Any insights? I am thoroughly confused by this.
