Author Topic: were to find dv on a 54 plate 2.0tdi  (Read 463 times)
Offline phil bert
« on: June 03, 2013, 06:18:01 pm »
ok so I been looking for alittle while and I cant spot it so if anybody can point me in the right direction to find the dv that be great or pictues even better , thanks guys
if it not rubbing it aint dubbing
Offline torque777
Re: Re: were to find dv on a 54 plate 2.0tdi
« Reply #1 on: June 03, 2013, 07:05:30 pm »
If you mean dump valve  ? There isn't one on 2.0tdi pd engine ....only a egr at front of engine
sent using my own fingers
Offline phil bert
« Reply #2 on: June 03, 2013, 07:19:52 pm »
diverter valve ? is what i'm thinking
Offline torque777
« Reply #3 on: June 03, 2013, 07:25:09 pm »
Can't ever remember a diverter valve ?? Will ask about
Offline Polo6n1600i
« Reply #4 on: June 03, 2013, 07:47:40 pm »
Forge use to make and upgraded diverter/recirc valve - think it was about £300 fitted??
Dump valve to atmosphere = bad idea for a diesel (turbo stall!)
Diverter/ recirc valve = no benefit £300 worse off.
You want a tdi to chirp, cut the airbox & a performance filter. Then a cat bypass and a straight through exhaust system!!
My old Fabia VRS sounded amazing
