Author Topic: Fitting Highline? and upgrading steering wheel?  (Read 15218 times)
WILLZIE
Re: Fitting Highline? and upgrading steering wheel?
« Reply #15 on: August 25, 2009, 02:01:45 pm »
Unfortunetly not, my dealer doesn't do after market mods-not even cruise. I think the nearest could be JKM performance in Portsmouth or tuningwerks in Croydon!..are they the people who could do this?
« Reply #16 on: August 25, 2009, 02:12:59 pm »
no mate, you'd need to go to a dealer, or some shady character that can do mileage correction.
im sure the dealers wouldnt be impressed if the clocks had been changed without going to them. it leaves the door open for dodgy mileage input, thats why i went to the dealer
WILLZIE
« Reply #17 on: August 25, 2009, 02:16:27 pm »
Ah I see (of course!), so what is it I would need the dealer to actually do then?
« Reply #18 on: August 25, 2009, 02:34:24 pm »
supply the clock, fit it (two screws) and then code it and make sure all the immobiliser works
WILLZIE
« Reply #19 on: August 25, 2009, 02:41:44 pm »
that easy? what about finding out if mine supports that central electrics control module first?
Just need all th info, as this is somin I will probly get done if possible)
« Last Edit: August 25, 2009, 02:44:55 pm by WILLZIE »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #20 on: August 25, 2009, 02:42:06 pm »
Dealers cannot correct mileage.
Anyone (who knows what they are doing) with VCDS (VAG-COM) can install it providing you have the two SKC's (Secret Key Codes).  If you don't then you need someone with the correct tools to extract the codes or a dealer who will use VAS to go online and read them.
I've done a few myself, both using VCDS and VAS the dealer tool.
Stu...
WILLZIE
« Reply #21 on: August 25, 2009, 02:56:42 pm »
Found this link supplied but VC..looks intense as it shows the back seats being removed, but hazard a guess its for an early model Gti!?
http://forums.vwvortex.com/zerothread?&id=3604801&postid=44436951#44436951
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #22 on: August 25, 2009, 03:05:58 pm »
Good DiY but much more in depth than you need to worry about.
VAG-CAN Commander is the tool used to extract the SKC's if you don't have them.  It can also modify the mileage.
Stu...
WILLZIE
« Reply #23 on: August 25, 2009, 03:10:42 pm »
So its just a case of swaping the clocks over at the main dealer ( just not mine) anyone know of a deler that will do this locally to Sussex?
« Reply #24 on: August 25, 2009, 03:23:15 pm »
any should be capable of doing it mate, its not a massively hard procedure at all.
the hard part (for us) is getting SKCs out of new clocks
WILLZIE
« Reply #25 on: August 25, 2009, 04:14:52 pm »
Ok, cheers guys, may ring round a few dealers when I have time and see what they will say. I got a no last time from my dealer as they thought it could void some of my warranty!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #26 on: August 25, 2009, 04:19:21 pm »
The procedure for them is a simple dash insert replacement.  All carreid out with Guided Functions on VAS.
Stu...
WILLZIE
« Reply #27 on: August 25, 2009, 04:33:56 pm »
Whats the compass module that lives in the boot hatch for the highline bit?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #28 on: August 25, 2009, 04:34:30 pm »
That's not for UK cars.
Stu...
« Reply #29 on: August 25, 2009, 04:40:45 pm »
no, and its not worth fitting either at all.
One, its a nightmare to fit.
Two, it will only serve to conflict with data on the system already
