Author Topic: Fitting Highline? and upgrading steering wheel?  (Read 9808 times)
WILLZIE
Re: Fitting Highline? and upgrading steering wheel?
« Reply #30 on: August 25, 2009, 04:46:40 pm »
Thats probly were I'm seeing it all as a nightmare, 1 guy going OTT as hes even playing with the horn! Just makes me think why more people haven't had this done!?
Plus it gets rid of a small scratch on the clock from previous owner.
« Reply #31 on: August 25, 2009, 04:57:57 pm »
you ca physically swap a set of clocks in less than 30 seconds if you wanted mate, its just the coding side of things that complicates things
WILLZIE
« Reply #32 on: August 25, 2009, 06:27:46 pm »
Ok ta, I thought it was all cutting into canbus lines and all the impossible stuff!
Offline mortygttdi
  • -Receive: 146
« Reply #33 on: August 29, 2009, 08:31:53 pm »
Willzie if you have a midline cluster then you have a part highline central electrics module most if not all GT/GTI will have the Midline/Highline.
Darren
Offline tecas
« Reply #34 on: September 28, 2009, 10:03:53 pm »
Interesting thread guys.  I changed my lowline to midline succesfully a while back but was looking to get a second hand highline to upgrade once more.  The research I have done suggests that Vag CAN Commander only retrieves SKC's from a cluster for up to 2006MY models.  Is this still the case?
I occasionally see the highlines popping up on ebay but they are always for the newer vehicles (mine is 2004 model).
« Reply #35 on: September 28, 2009, 10:05:09 pm »
Yep your right on that mate
Offline tecas
« Reply #36 on: September 28, 2009, 10:08:49 pm »
If you are replying to me, I barely posted and you responded.  Remarkable :smiley:
So that's one thing to be wary of then.  If you won't be able to retrieve the SKC (unless you're a main dealer) from a cluster from a 2007MY Golf onwards.
« Reply #37 on: September 28, 2009, 10:32:46 pm »
Yep I was talking to you matey lol. And your right. It's a dealer only or some shady mileage correction specialist. It was a dealer for me so everything was documented on official vw job cards etc
Offline tecas
« Reply #38 on: September 28, 2009, 10:48:25 pm »
OK, thanks for the info'.  Maybe that's the only way to go then, especially if one is fitting a 2007 onwards cluster!  I will continue to search out a highline cluster from a 2004/2005 model and then it will be a lot more cost effective  :happy2:  Until them I am happy with my midline....at least I get to know the outside temperature, my old one never had that even!
